pmdental(at)btinternet.co Guest
Posted: Tue Dec 29, 2015 9:37 am Post subject: Drip trays ??? |
dpark748(at)icloud.com Guest
Posted: Tue Dec 29, 2015 9:46 am Post subject: Drip trays ??? |
I have a drawing for one somewhere, i will send it to you. Not necessary but catches any fuel from carbs and drains away from exhaust pipes!?!?!?
Dave G-LDVO
On 29 Dec 2015, at 17:35, Paul & Vanessa Munford <pmdental(at)btinternet.com (pmdental(at)btinternet.com)> wrote:
alan.twigg775(at)gmail.co Guest
Posted: Tue Dec 29, 2015 11:58 am Post subject: Drip trays ??? |
David, I am also at that point, can you share the drawing.
When will I fly??
Alan Twigg
Motorglider
Kit 463
Sent from my iPad
On 29 Dec 2015, at 17:45, david park <dpark748(at)icloud.com (dpark748(at)icloud.com)> wrote:
[quote]I have a drawing for one somewhere, i will send it to you. Not necessary but catches any fuel from carbs and drains away from exhaust pipes!?!?!?
Dave G-LDVO
pete(at)lawless.info Guest
Posted: Tue Dec 29, 2015 12:16 pm Post subject: Drip trays ??? |
Hi Both
Conair Sports link
http://www.ekmpowershop2.com/ekmps/shops/conairsports/item-20---874300-drip-tray-896-p.asp
Pete
On 29/12/15 19:57, Alan Twigg wrote:
[quote] David, I am also at that point, can you share the drawing.
When will I fly??
Alan Twigg
Motorglider
Kit 463
Sent from my iPad
On 29 Dec 2015, at 17:45, david park <[url=mailto:dpark748(at)icloud.com]dpark748(at)icloud.com (dpark748(at)icloud.com)[/url]> wrote:
[quote] I have a drawing for one somewhere, i will send it to you. Not necessary but catches any fuel from carbs and drains away from exhaust pipes!?!?!?
Dave G-LDVO
On 29 Dec 2015, at 17:35, Paul & Vanessa Munford <[url=mailto:pmdental(at)btinternet.com]pmdental(at)btinternet.com (pmdental(at)btinternet.com)[/url]> wrote:
Posted: Tue Dec 29, 2015 2:52 pm Post subject: Drip trays ??? |
Paul, Drip trays came as standard with my 914 back in 2001, and I see that the 2015 914 installation manual still calls for them to be fitted and shows a diagram on p93. It could be that this relates to the high manifold pressure having much greater liability to fuel leaks than the normally aspirated 912s. Have to say I have never noticed any hint of a leak, but it could be of course that the system vents it harmlessly out through the air vent, which would not have been the case had it dropped on the exhaust!
Regards, David Joyce, GXSDJ
On 2015-12-29 17:35, Paul & Vanessa Munford wrote: [quote]
Posted: Wed Dec 30, 2015 1:01 am Post subject: Drip trays ??? |
Paul, Now I come to check it, the 2015 912 installation manual has a drip tray clearly visible on the front cover picture and it is referenced in the text, so not a peculiarity of the 914. David
On 2015-12-29 22:51, davidjoyce(at)doctors.org.uk wrote: [quote]
