Air Gauges
yakadillo(at)gmail.com
PostPosted: Sun Jan 31, 2016 7:23 am    Post subject: Air Gauges Reply with quote
Howard Francis can repair a twin or single pressure gauge for under $100.  He says the copper tubing the air goes through has a very small orifice and water and copper have a corrosive interaction which can plug this small orifice. He can also rescreen the russian airspeed dial.  His contact info:
Home:  [url=tel:480-820-0405]480-820-0405[/url]
Cell: [url=tel:480-467-7163]480-467-7163[/url]
Email: htfrancis38(at)aol.com (htfrancis38(at)aol.com)
Scott Miller
Ernie
PostPosted: Sun Jan 31, 2016 7:36 am    Post subject: Air Gauges Reply with quote
Is it just me, or is anyone else getting list messages completely out of context. Is the list dropping messages? I'm assuming this post was in response to another post which I never got.
Ernie
On Sunday, January 31, 2016, Scott Miller <yakadillo(at)gmail.com (yakadillo(at)gmail.com)> wrote:
Email: [url=javascript:_e(%7B%7D,'cvml','htfrancis38(at)aol.com');]htfrancis38(at)aol.com[/url]
Scott Miller
cjpilot710(at)aol.com
PostPosted: Sun Jan 31, 2016 7:47 am    Post subject: Air Gauges Reply with quote
Same here. Jim "Pappy" Goolsby
Viperdoc
PostPosted: Sun Jan 31, 2016 7:52 am    Post subject: Air Gauges Reply with quote
Same Ernie.
Doc
Sent from my iPad
On Jan 31, 2016, at 9:33 AM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
Ernie
Email: [url=javascript:_e(%7B%7D,\'cvml\',\'htfrancis38(at)aol.com\');]htfrancis38(at)aol.com[/url]
Scott Miller
Viperdoc
jbsoar(at)gmail.com
PostPosted: Sun Jan 31, 2016 8:18 am    Post subject: Air Gauges Reply with quote
Scott-what gauge does the 52 use?  I'd like to install a pressure gauge in the Yak 55.  I'm not sure how to plumb it.Thank you!
Scott Miller
dsavarese0812(at)bellsout
PostPosted: Sun Jan 31, 2016 8:47 am    Post subject: Air Gauges Reply with quote
John,
Regardless of what pressure gauge you use, plumb it before the main air
valve. The 52's gauge has two gauges built into one instrument head;
for both the main and emergency.That way you'll be able to read the air
pressure in the main air tank without having to turn on the main air
valve. Wastes precious air when you have to turn on the main air valve
just to read the air pressure in the main air tank.52 is plumbed this
way. CJ is not- at least on the main air side.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Thank you!
Home: 480-820-0405 <tel:480-820-0405>
Cell: 480-467-7163 <tel:480-467-7163>
<javascript:_e(%7B%7D,'cvml','htfrancis38(at)aol.com');>
Scott Miller
L29delfin(at)yahoo.com
PostPosted: Sun Jan 31, 2016 8:58 am    Post subject: Air Gauges Reply with quote
My experience . This yak 52 air gauge is very hard to find and expensive. So being able to repair it would be welcome news. B
Sent with AquaMail for Android
http://www.aqua-mail.com
Scott Miller
heaysr(at)telus.net
PostPosted: Mon Feb 01, 2016 7:07 pm    Post subject: Air Gauges Reply with quote
John,
There is no air valve (shut of valve) on a Yak 55M. It's a very simple system relative to a Yak 52. You can T off a line that is exposed to permanent air pressure from receiver to the pressure relief valve under the cockpit floor that is accessible from the removable inspection cover aft of the fire wall under the fuselage.
The gauge can be selected from any manufacturer that does bourdon tube gauges at 1000 psi or 70 bars. If the gauge is oil (linseed) filled for damping, I suggest the oil be drained out as it will leak out anyway, what with variations in altitude and make a big mess.
"Winters" is one of many manufacturers with various dial sizes, and attachment entries (bottom or back). I find that they eventually leak air after a few years, so I suggest you get an extra as a spare.
Royden
jbsoar(at)gmail.com
PostPosted: Mon Feb 01, 2016 7:17 pm    Post subject: Air Gauges Reply with quote
Royden-thank you!  This really helps.  Who sells new metric tubing and fittings?
On Monday, February 1, 2016, Royden Heays <heaysr(at)telus.net (heaysr(at)telus.net)> wrote:
[quote]--> Yak-List message posted by: "Royden Heays" <[url=javascript:;]heaysr(at)telus.net[/url]>
John,
Royden
heaysr(at)telus.net
PostPosted: Mon Feb 01, 2016 11:08 pm    Post subject: Air Gauges Reply with quote
Hello John,
I’m no expert on that. My 55M came already fitted. The gauges I mention  are NTP thread.
However, a top quality manufacturer of tubes and fittings is Swagelok. They do both metric and imperial. Try Googling them and then find a local distributor.
Royden
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of John B
Sent: Monday, February 1, 2016 7:13 PM
To: yak-list(at)matronics.com
Subject: Re: Air Gauges
On Monday, February 1, 2016, Royden Heays <heaysr(at)telus.net (heaysr(at)telus.net)> wrote:[quote]
John,
Royden
jbsoar(at)gmail.com
PostPosted: Tue Feb 02, 2016 12:40 am    Post subject: Air Gauges Reply with quote
Royden-
Where is your pressure gauge located?
john b
On Tue, Feb 2, 2016 at 12:01 AM, Royden Heays <heaysr(at)telus.net> wrote:
[quote] Hello John,
are NTP thread.
distributor.
Royden
*From:* owner-yak-list-server(at)matronics.com [mailto:
owner-yak-list-server(at)matronics.com] *On Behalf Of *John B
*Sent:* Monday, February 1, 2016 7:13 PM
*To:* yak-list(at)matronics.com
*Subject:* Re: Air Gauges
fittings?
On Monday, February 1, 2016, Royden Heays <heaysr(at)telus.net> wrote:
John,
Royden
Viperdoc
PostPosted: Tue Feb 02, 2016 6:20 pm    Post subject: Air Gauges Reply with quote
McMastercar has aluminum and cooper tubing in metric sizes. Use your old fitting when you do the fairs.
Doc
Sent from my iPad
On Feb 1, 2016, at 9:13 PM, John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
[quote]Royden-thank you! This really helps. Who sells new metric tubing and fittings?
John,
Royden
Viperdoc
heaysr(at)telus.net
PostPosted: Tue Feb 02, 2016 6:30 pm    Post subject: Air Gauges Reply with quote
Hi John,
It is on the fuselage frame at the seat back station, left side. That’s close to the external filling fitting.  I need to have a rubber neck to read it at that location! It is soft mounted with ties so as not to drill any holes in the frame. It works fine.
My buddy has his mounted under the instrument panel on the left side. Easier to read.
Royden
Sent: Tuesday, February 2, 2016 12:35 AM
To: Yak-List Digest Server <yak-list(at)matronics.com>
Royden-
john b
On Tue, Feb 2, 2016 at 12:01 AM, Royden Heays <heaysr(at)telus.net (heaysr(at)telus.net)> wrote:[quote]
Hello John,
Royden
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of John B
--> Yak-List message posted by: "Royden Heays" <heaysr(at)telus.net (heaysr(at)telus.net)>
John,
Royden
