Rotax 914 Generator, Alternator, Starting and Fuel Pump Co
PostPosted: Fri Jan 22, 2016 5:21 pm    Post subject: Rotax 914 Generator, Alternator, Starting and Fuel Pump Co Reply with quote
At 09:01 AM 1/22/2016, you wrote:
1. Over voltage protection.
Bob Nuckolls made a demonstration board for an court trial. He made a movie showing what happens when fuses or circuit breakers are in series. If Bob is reading, maybe he can provide a link to that movie.
The specific video is at:
http://tinyurl.com/ppdv5fg
The sum total of the accident analysis can be
seen at:
http://tinyurl.com/msfmldj
It was interesting. Anyway, even a 10 amp fuse might blow before a 5 amp series breaker trips.
I've opened 20A fuses through 5A breakers
5. The reason that I suggested using a smaller breaker for the output of the 20 amp dynamo is that in the event of a short circuit, a 20 amp breaker might not ever trip because the dynamo will struggle to put out that much current.
I'm aware of NO engine driven power source
that is capable of opening its own output
protection. Fuses, breakers, fusible links
and current limiters protect wires . . . nothing
more. Further, that protection needs to be
installed facing the probable source of energy
feeding the fault. In our itty-bitty airplanes,
this is almost ALWAYS the battery.
Hence, alternator output protection goes as
close to the battery as practical. It is robust
enough to stay closed under most energetic output
the alternator can produce. I've written about
the "breaker designed to nuisance trip" that
was built into tens of thousands airplanes . . .
a 60A breaker on 60A alternator.
In the case of feeder protection for a 10-20A
PM alternator/rectifier-regulator, a 30A fuse
or mini current limiter is not too big and it
CANNOT be nuisance tripped by alternator output.
If some failure puts the alternator itself at
risk . . . so be it. Let the alternator smoke,
protect the wires and go to plan-B.
PostPosted: Fri Jan 29, 2016 5:51 am    Post subject: Rotax 914 Generator, Alternator, Starting and Fuel Pump Co Reply with quote
At 01:01 PM 1/22/2016, you wrote:
--> AeroElectric-List message posted by: "Ross Home" <rossmickey(at)comcast.net>
With a download time of 11 hours, I think I will pass even though it looks
interesting.
Thanks for posting it though.
send me your mailing address and I'll put
the set of files on a CD for you . . .
