kearney
Posted: Tue Feb 23, 2016 6:14 pm Post subject: Fuel Caps |
Hi
I have been wondering about how hard it should be push the locking tab on a fuel cap into place. One of mine was very, very difficult so I ended up backing off the retaining nut.
Anyway, is there any lubrication (fuel lube perhaps) required.
How snug should the tab be?
Inquiring minds need to know.
Les
Dave Saylor
Posted: Tue Feb 23, 2016 6:47 pm Post subject: Fuel Caps |
The thermos bottle caps take some regular maintenance. You'll need a little light grease on the lobe of the handle cam. I found a grease called Krytox (sorry, there are several types and I don't recall which I went with) for the oring. Works great.
Fuel lube, contrary to what the name implies, is really a sealant and will gum up the works in short order. It works best to lube pipe threads, etc. between dissimilar metals, ie, to prevent galling aluminum pumps and such. And it's fuel proof, but not exactly slippery.
--Dave
On Tue, Feb 23, 2016 at 6:14 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
| Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Les
http://forums.matronics.com/viewtopic.php?p=453106#453106
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
-Matt Dralle, List Admin.
FORUMS -
b Site -
_________________ --Dave
KWVI |
Kellym
Posted: Tue Feb 23, 2016 7:09 pm Post subject: Fuel Caps |
While not identical, Beech and Mooney fuel caps require something like
Triflow or silicone lube on O-rings. I've also used DC-4 where I wanted
to last longer...same stuff you use on oil filter o-ring.
On 2/23/2016 7:14 PM, kearney wrote:
Hi
Les
KCHD |
Dave Saylor
Posted: Tue Feb 23, 2016 7:41 pm Post subject: Fuel Caps |
I found my old order for Krytox:
http://www.mcmaster.com/#dupont-krytox-gpl-206-grease/=119achu
A 1/2 oz tube has lasted for a couple seasons now-- $$$ but worth it. Avgas doesn't seem to phase it.
I only use it on the fuel cap orings.
--Dave
On Tue, Feb 23, 2016 at 7:05 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
| Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
While not identical, Beech and Mooney fuel caps require something like Triflow or silicone lube on O-rings. I've also used DC-4 where I wanted to last longer...same stuff you use on oil filter o-ring.
Hi
Les
br> fts!)
r> > href="http://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
FORUMS -
b Site -
KWVI |
