Posted: Sun Mar 13, 2016 11:15 am Post subject: Getting the trim motor out |
Somewhat to my dismay, (tho i dare say it would have been a little more dismaying in flight) I have discovered loose connection to the trim. I suspect the connection twixt 5 core wire and trim motor.
I did thoroughly check it before i put the top on.
I think I need to get the trim motor out as I cant see a way of getting to it to check the wires.
Is there a trick to this?
Thanks Will
klinefelter.kevin(at)gmai Guest
Posted: Sun Mar 13, 2016 12:00 pm Post subject: Getting the trim motor out |
I had the RayAllen relay go bad on my trim a while back.
Do you have a relay?
On Mar 13, 2016, at 12:14 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Thanks Will
Posted: Sun Mar 13, 2016 12:05 pm Post subject: Getting the trim motor out |
Ummm dunno. Its the stuff that came with the kit.
Will On Mar 13, 2016 3:03 PM, "Kevin Klinefelter" <klinefelter.kevin(at)gmail.com (klinefelter.kevin(at)gmail.com)> wrote: | Quote: | I had the RayAllen relay go bad on my trim a while back.
Thanks Will
Posted: Sun Mar 13, 2016 12:33 pm Post subject: Getting the trim motor out |
If you have two trim controls, one on the stick and one by the trim display perhaps, then there is a relay between them.
On Mar 13, 2016, at 1:04 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Thanks Will
Posted: Sun Mar 13, 2016 1:07 pm Post subject: Getting the trim motor out |
Nope...just the panel mount rocker. On 13 Mar 2016 15:36, "Kevin Klinefelter" <klinefelter.kevin(at)gmail.com (klinefelter.kevin(at)gmail.com)> wrote: | Quote: | If you have two trim controls, one on the stick and one by the trim display perhaps, then there is a relay between them.
Thanks Will
stranfaer(at)btinternet.c Guest
Posted: Sun Mar 13, 2016 1:23 pm Post subject: Getting the trim motor out |
It was the trim relay that caused my problem in September, google AAIB G-BXGG for details, trim gave full back stick on take off completely uncommanded.
Kevin what happened with yours?
rgds
David
The other one
On Sunday, 13 March 2016, 19:59, Kevin Klinefelter <klinefelter.kevin(at)gmail.com> wrote:
Do you have a relay?Sent from my iPhone
| Quote: | Somewhat to my dismay, (tho i dare say it would have been a little more dismaying in flight) I have discovered loose connection to the trim. I suspect the connection twixt 5 core wire and trim motor.
Thanks Will
Posted: Sun Mar 13, 2016 1:52 pm Post subject: Getting the trim motor out |
Hi! Will
I had a Ray Allen Relay deck fail on a dual trim control system. I had a problem which wouldn’t reverse the trim until it reached fully trimmed nose up mode . Once trim up had been engaged it would not reverse until the motor reached its full limit , then it would reverse. I may add that this scenario was very hairy since the stick loads were so intense it needed the passenger to assist. In the end I used to allow it to go momentarily fully up without restraint , but it took some “guts” to allow that . You would not land the aircraft with full trim up loads held on the control stick.( not withstanding the loads encountered would test the controls to the limit!)
I had this issue twice and Ray Allen on both occasions claimed it to be a wiring installation issue ......not their motor or Relay deck. On the third occasion , I discovered that they had introduced a MK II relay deck and on discussion with them they advised that they had discovered an inbuilt fault in the Mark I version of the deck in that as soon as the fault was reversed it hid the fault of failure to reverse. I had to ask them ......they did not volunteer the information and twice actually insisted it was a fault in my wiring
I changed the relay deck for the Mark II supplied at a discount and have had no problem since. However not before having “pulled” the motor twice on wasted errands!
I had on original build predicted the necessity to remove the trim motor and arranged it’s mounting with “ home brewed” stiff nuts held in place specially for such a “jiggery pokery” issue . So you will get to change the motor with great difficulty ! Be well advised to check out every last detail of motor and relay deck and even change the MKI deck for a MK II as a matter of course prior to “digging” the motor out !
Bob Harrison G-PTAG .
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: 13 March 2016 19:14
Subject: Getting the trim motor out
Thanks Will
Posted: Sun Mar 13, 2016 2:03 pm Post subject: Getting the trim motor out |
Mine just became intermittent, no uncommanded runaways.
Will, if you don't have more than just the one rocker switch then you would not have a relay.
On Mar 13, 2016, at 2:19 PM, <stranfaer(at)btinternet.com (stranfaer(at)btinternet.com)> <stranfaer(at)btinternet.com (stranfaer(at)btinternet.com)> wrote:
rgds
David
The other one
On Sunday, 13 March 2016, 19:59, Kevin Klinefelter <klinefelter.kevin(at)gmail.com (klinefelter.kevin(at)gmail.com)> wrote:
Thanks Will
