chasfwhite(at)gmail.com Guest
Posted: Sun Mar 13, 2016 3:40 pm Post subject: Converting my MK3 to Dual Control |
For about 20 yrs. I have been looking at my MK 3-912's single center control and wondering / wishing it was dual control. It's not so much that I want another control on the passenger side, I just want to be able to control the plane with my left hand and a stick between my legs and my right had on the throttle... like most planes.
I looked back in the archives and found a few pros/cons and how it's difficult for us "big boys 6'2"-240... to crawl in & out with stick in your way, but nothing about the process or difficulty of the conversion itself.
I met John H. yrs. ago at Sun'nFun and thought his and a few other planes were configured that way and have had that project in my mind ever since.
I'm right in the middle of changing the gear legs to spring steel and adding bigger tires, so maybe it's time to make that control change too.
I sent the Kolb folks a note requesting information on the parts required, but would appreciate anyone's thoughts on the dual control set-up?
Thanks...
Charles White
Rollins,,Montana
Posted: Sun Mar 13, 2016 4:21 pm Post subject: Converting my MK3 to Dual Control |
Well, I am proud to say my Brother Jim and good friend Seth Mathews, RIP, designed and built the first set of dual controls for a Kolb MKIII back in 1991. After 25 years and 3,300+ hours, they still work like brand new.
I fly from the right seat, so I was able to use the throttle in its normal MKIII position between the seats. Left hand on the throttle and right hand on the stick.
I normally do not fly with the left stick installed. This facilitates loading and unloading passengers.
As I get older it is a little more difficult to get the left foot over the stick, but I can still do it without too much hassle.
Nothing wrong with the center mounted single stick. The geometry is just right and has a good control feel. Was a little awkward at first, but became normal very quickly. Used to fly all day to get to Sun and Fun in my MKIII with the stick between my legs, then get out and get in the factory MKIII and fly side stick and arm crossed across my belly to control throttle. My big problem was reaching up with my left hand to pull flaps on final.
Good luck with you dual controls.
I landed at Polson, MT, in 2004, on the way to Alaska. Flew right over Rollins on the way north.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of C. White
Sent: Sunday, March 13, 2016 6:39 PM
Subject: Converting my MK3 to Dual Control
Thanks...
Charles White
Rollins,,Montana
_________________ John Hauck
Titus, Alabama |
byoungplumbing(at)gmail.c Guest
Posted: Sun Mar 13, 2016 5:03 pm Post subject: Converting my MK3 to Dual Control |
Instead of dual controls. I modified my center control. I made a sleeve that slides over the top of the stick, Then welded a tube to the top of the sleeve at a 90 deg pointing to the left. drilled and secured it on the stick with a couple screws.
I can fly left or right handed, while flying left handed I can reach both throttle and flaps with right hand. With the right hand on the stick it is like a conventional mkiii
Boyd Young
Mkiii
Utah On Mar 13, 2016 5:43 PM, "C. White" <chasfwhite(at)gmail.com (chasfwhite(at)gmail.com)> wrote: | Quote: | For about 20 yrs. I have been looking at my MK 3-912's single center control and wondering / wishing it was dual control. It's not so much that I want another control on the passenger side, I just want to be able to control the plane with my left hand and a stick between my legs and my right had on the throttle... like most planes.
Thanks...
Charles White
Rollins,,Montana
ceengland7(at)gmail.com Guest
Posted: Sun Mar 13, 2016 8:22 pm Post subject: Converting my MK3 to Dual Control |
Sounds like what I was about to suggest. Try to find a pic of a Whitman Tailwind stick.
Date:03/13/2016 7:58 PM (GMT-06:00)
Subject: Re: Kolb-List: Converting my MK3 to Dual Control
Boyd Young
Mkiii
Thanks...
Charles White
Rollins,,Montana
