Brass Strap alternative in Z-19RB
haribole
PostPosted: Fri Mar 25, 2016 5:26 pm    Post subject: Brass Strap alternative in Z-19RB Reply with quote
I have the batteries under the pilot and co-pilot seats. Z-19RB is designed with both the batteries together and hence the connections between the main battery contactor and the engine battery contactor is shown as a brass strap.
Can I replace this with a cable instead?  The length would be approximately 24". If yes, what guage of cable should I be using?
Hari
 Filesize:  12.75 KB
 Viewed:  3037 Time(s)
