flight home from the rock house
byoungplumbing(at)gmail.c
PostPosted: Mon Mar 28, 2016 8:25 am    Post subject: flight home from the rock house Reply with quote
just for information.... on my way home from the rock house to Utah,,,, when I descended into Buhl Idaho for fuel, my 912 started running a bit rough. it was not continuous just a split second of rough then smooth right out. � but it repeated itself every few seconds. after refueling I did a run up, every seemed to run smooth. so I thought that I maybe had had a bit of carb ice... I took off with the thought of returning if all did not sound or feel right... the 912 purred like always.... until I reached altitude and throttled back. this time the vibration had only short periods of smooth between long rough periods. I tried the enrichener, but that made it much worse.... tried turning off both mags one at a time.... the mags made no difference.... went back to � WOT and things smoothed out... by this time I looked out the window and was over another airport, chopped power and landed.... The kid at the airport was just putting away his RV7 and was going home....� he hung around long enough till I got things running smoothly again.....� I checked the float bowls, all looked good, no debris or water. � then I noticed the float bowl vent tube, I have always had it vented into the air cleaners.... but on one side the tube had kinked. I asked for a bit of safety wire, � straightened out the tube wrapped the kink with the wire, put it back on,,, The wire kept the tube from folding over,,, I went for a high speed taxi text, then did a loop around the pattern.... everything ran smooth... so I departed for home, a 2 hour flight without problems.
moral of the story,,,, keep the float bowl vent lines open...
boyd young
www.avast.com
Arty Trost
PostPosted: Mon Mar 28, 2016 8:44 am    Post subject: flight home from the rock house Reply with quote
Hi Boyd,
Glad you figured out the problem and made it home safely. And thanks for posting this - one more thing to be sure to check out during mt pre-flights.
Arty
www.LessonsFromTheEdge.com/uladventure2009.htm
"Life's a daring adventure or nothing" Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
Sent: Monday, March 28, 2016 6:21 PM
Subject: flight home from the rock house
boyd young
www.avast.com
