billhuntersemail(at)gmail Guest
Posted: Wed Apr 06, 2016 8:31 am Post subject: Can someone PLEASE help me make some Circuit Breaker rating |
Can someone PLEASE help me make some Circuit Breaker rating decisions???
I finalized my components list and most of the components were easy to decide on a CB amp rating however the following list I am still unsure of. Can anyone PLEASE look it over and lend some assistance???
EQUIPMENT AMP MANUFACTURES DATA SHEET INFO
G-650 COM 10 GARMIN GNS650
Comm Connector .45A continuous 5.66A Max
G-650 NAV 3 Nav Connector .6A continuous 1.16A Max
G-650 MAIN 3 Main Connector 1.6A continuous 2.8A Max
AUDIO 3 SL-15 0.350amp typ 1.5amp max
XPNDR 3 Dynon SV-XPNDR-261 0.4amp
Dynon SV-ADSB-470 0.2amp
VOLT REG SENSE 2 LR3C-14 Voltage Regulator BUS VOLTAGE SENSE
VOLT REG FIELD 5 VOLTAGE REGULATOR FIELD
SV COM 5 SV-COM-425 0.2amp RCV 3 amp XMT
SVAP SERVO 5 SV-AP SERVO
Pitch servo 2 amps when moving at MAX torque
Roll servo 2 amps when moving at MAX torque
TAXI LIGHT 5 TAXI LIGHT
PITOT 10 DYNON #100667-000
10.0 amp max (at) max heat
FUEL QTY 2 PRINCETON CAPACITANCE PROBES (two probes total)
NAV 5 INCANDESCENT LIGHTS
STROBE 7.5 WHELEN HDACF 01-0770028-05
LAND 10 Landing Light
MISC LTS 5 INTERIOR LEDs AND MISC LIGHTS
STARTER 5 STARTER SOLENOID
USB 10 USB CHARGER AND LIGHTER SOCKET
THANKS!!!
Bill Hunter
dgaldrich
Joined: 24 Apr 2009 Posts: 267 Location: Naples, Fl and Belfast, ME
Posted: Wed Apr 13, 2016 4:17 pm Post subject: Re: Can someone PLEASE help me make some Circuit Breaker rat |
I seem to recall that CB's are generally used to protect the wire, not whatever the load is. Figure out what gage wire is used for the power supply and size the CB accordingly. Some items may specify a certain size CB and that would override the wire size dictum.
Dave
Joined: 28 Mar 2008 Posts: 1975 Location: Riley TWP Michigan
