cbirdsall6(at)cox.net Guest
Posted: Wed Apr 13, 2016 9:55 pm Post subject: Can someone PLEASE help me make some Circuit Breaker rating |
On the GNS 650, for 14V systems Garmin's install manual specifies two breakers. One 10A breaker for the Com connector and one 7.5A breaker which powers both the Nav and Main connectors.
Your current draw values are correct for the 650.
Chuck
On Apr 6, 2016, at 11:30 AM, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
<![endif]--> <![endif]-->
Can someone PLEASE help me make some Circuit Breaker rating decisions???
I finalized my components list and most of the components were easy to decide on a CB amp rating however the following list I am still unsure of. Can anyone PLEASE look it over and lend some assistance???
EQUIPMENT AMP MANUFACTURES DATA SHEET INFO
G-650 COM 10 GARMIN GNS650
Comm Connector .45A continuous 5.66A Max
G-650 NAV 3 Nav Connector .6A continuous 1.16A Max
G-650 MAIN 3 Main Connector 1.6A continuous 2.8A Max
AUDIO 3 SL-15 0.350amp typ 1.5amp max
XPNDR 3 Dynon SV-XPNDR-261 0.4amp
Dynon SV-ADSB-470 0.2amp
VOLT REG SENSE 2 LR3C-14 Voltage Regulator BUS VOLTAGE SENSE
VOLT REG FIELD 5 VOLTAGE REGULATOR FIELD
SV COM 5 SV-COM-425 0.2amp RCV 3 amp XMT
SVAP SERVO 5 SV-AP SERVO
Pitch servo 2 amps when moving at MAX torque
Roll servo 2 amps when moving at MAX torque
TAXI LIGHT 5 TAXI LIGHT
PITOT 10 DYNON #100667-000
10.0 amp max (at) max heat
FUEL QTY 2 PRINCETON CAPACITANCE PROBES (two probes total)
NAV 5 INCANDESCENT LIGHTS
STROBE 7.5 WHELEN HDACF 01-0770028-05
LAND 10 Landing Light
MISC LTS 5 INTERIOR LEDs AND MISC LIGHTS
STARTER 5 STARTER SOLENOID
USB 10 USB CHARGER AND LIGHTER SOCKET
THANKS!!!
Bill Hunter
