SHT3x Digital/Analog Humidity Sensors - Sensirion | DigiKey
yellowduckduo(at)gmail.co
PostPosted: Tue Apr 26, 2016 4:45 am    Post subject: SHT3x Digital/Analog Humidity Sensors - Sensirion | DigiKey Reply with quote
Stu
Much cheaper and easier to pick up little circuit assemblies marketed
for arduino projects or similar on ebay. There are several versions of
humidity sensors for a couple of dollars. I'd use a $3. arduino pro mini
as the controller. Similarly there are power relays that interface for a
couple of $.
Ken
On 26/04/2016 8:20 AM, Stuart Hutchison wrote:
G’day Bob,
Do you reckon it would be easy to build a circuit accommodating these
new humidity sensors (digital and analogue options) for an engine
dehumidifier that automatically switches between an aquarium pump and
an incandescent heat bulb dry out the silica desicant?
> http://www.digikey.com.au/en/product-highlight/s/sensirion/sht3x-digital-and-analog-humidity-sensors?WT.v_sub=6908894&WT.mc_id=em_NPA1604B.AU.Send&WT.z_email=6249_NPA1604BI0AU_supplier6image--1649-Sensirion&mkt_tok=eyJpIjoiTmprME9HVXlaR0pqWVRjeiIsInQiOiJlSGlHNGpRbzFVMVwvbmJHMFppZmNUSG9INmphQnJWZjRlWWRHZ09uWGNONWxPcVlGaStzRFpGVGZSMTdBZ1FpVVFNQUxhZHRYU0UwVjBQME41Wng2VFwvZEg5ajI3YWZoNk9BdlJLZk5oNTJzPSJ9
Cheers, Stu
