CH-701 Jigging Cabin Frame, Firewall and Engine Mount
pdelano(at)telus.net
PostPosted: Sun May 29, 2016 11:05 am    Post subject: CH-701 Jigging Cabin Frame, Firewall and Engine Mount Reply with quote
Hi All,
Following the procedures in the plans and manual for levelling fuselage, Hz tubes on cabin frame and engine mount, I jigged drilled and cleco'd the cabin frame to the AC. I supported the assembly at the
bottom of the firewall to get everything level (Fwd fuse is rivetted to rear fuse). When all was done I pulled the support from under the firewall, and of course everything sagged a bit leaving
the side tubes with a slight decline angle from level from back to front.
My plan now is to pull apart the cabin frame de-burr, prime and cleco it back together, then with the support under the firewall installed again, to keep everything level, rivet the cabin frame and continue with the rest of the Fwd fuselage structure, maintaining
the support under the firewall to keep everything level until all is primed, de-burred and rivetted together. This assumes the remaining structure to be added will stiffen and maintain the structure in a level orientation as dictated by the plans.
Would appreciate your comments or experience with the latter.
Perry Delano
