sailor2645(at)aol.com Guest
Posted: Sat May 28, 2016 3:25 am Post subject: Compressor Yak55M |
Does anyone have experience with repairing a compressor on the Yak55? My compressor has been intermittent for the past dozen flights, sometimes achieving 600 psi but lately only 400 psi.
I suspect the second stage is failing. Reading the manual does not shed any light on what to do. Any ideas?
Dan Caldwell
Sent from my iPad
Viperdoc
Posted: Sat May 28, 2016 12:05 pm Post subject: Compressor Yak55M |
How long has it been since the check valve was pulled and cleaned. You will most likely have to pull your compressor though. Check with George or Cliff Coy for a replacement.
Doc
Sent from my iPad
Quote: | On May 28, 2016, at 6:24 AM, Dan caldwell <sailor2645(at)aol.com> wrote:
Dan Caldwell
Sent from my iPad
_________________ Viperdoc |
heaysr(at)telus.net Guest
Posted: Sun May 29, 2016 2:00 pm Post subject: Compressor Yak55M |
I agree with Doc.
Also;
· Take a look at the banjo fitting at the compressor. It does gum up with cooked oil. Take it apart and clean it. Can be done without removing the compressor.
· Check the air intake filter is clean (not likely to cause the problem you describe)
· Check the valve at the snot collector below the air receiver that it is properly closed.
· There is a check valve in the line that gums up too. Take it apart and clean it.
· Check that the over pressure relief valve is closing properly. It can get gummed up and not seat properly. It's under the cockpit floor accessible through a covered opening in the fuselage.
Do your Yak 55M have a compressor unloader fitted? If not, the system gums up faster as the compressor is pumping all the time and the pressure relief valve is popping all the time.
Royden
C-GRED, Yak 55M
