Guy Buchanan
Posted: Thu May 19, 2016 3:53 pm Post subject: Rotax 912 UL Radiator Cap |
OK. Today I confirmed that BMW 17112345074 radiator cap works with the 912s.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 600 hrs
Glider pilot, too
On 3/20/2016 9:16 AM, Guy Buchanan wrote:
| Quote: | No. I never had a reason to do the replacement, but I'll give it a try this week to see if it works. It certainly looks identical, so I have little doubt that it does, but I'll give it a run next weekend to make sure and I'll get back to you.
Guy
On 3/19/2016 1:31 PM, Hugh McKay wrote:
| Quote: | Guy,
Did you ever replace the radiator cap on your 912-S with the BMW cap you bought? If so, did it fit?
Hugh G. McKay III, P.E. Fellow, L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
http://www.wwegeo.com
Sent: Sunday, October 18, 2015 2:49 PM
To: Hugh McKay (hgmckay(at)bellsouth.net)
Subject: Re: Rotax 912 UL Radiator Cap
Well I'm not going to tell you that it's the same part, but I purchased one and it looks and feels identical. And I have to tell you I haven't used it yet. And yes, I'm replacing the cap on an S. I don't know if the 80 uses the same part.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again.
Now a glider pilot, too.
On 10/17/2015 4:43 AM, Hugh McKay wrote:
| Quote: | Guy,
Â
Did I understand correctly from your 8/9/15 email on the Rotax Matronics forum that the BMW Radiator Cap part # 17112345074 will also replace the 1.2 bar cap for a 912 UL? I notice your Kitfox engine was a 912 –S. The engine on my Allegro 2000 is a 912 UL.
Â
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
Deceased K-IV 1200
A glider pilot too. |
