GAS CAP on model 2 header tank
turbot
PostPosted: Sat Jun 11, 2016 12:10 pm    Post subject: GAS CAP on model 2 header tank Reply with quote
Am replacing a cracked header tank gas cap on a KF2.
Found a universal snowmoble cap that is identical.
The cracked original has a homemade vent line coming out the top . Its a fuel line bent in a pig tail loop with a wire inside to hold the loop shape.
I drilled the new cap with a tiny hole for a vent , But am wondering if that is ok, is the pig tail line needed to prevent syphoning or to break a low pressure area ?
Any experiences out there ?
