Dawg
Posted: Mon Jun 13, 2016 3:10 pm Post subject: air |
It takes about 2 hours to build up air from 3 to 4??? (At cruise)
If I don’t have 4 minimum, engine won’t start.
Any ideas?
_________________ Dawg |
dougsappllc(at)gmail.com Guest
Posted: Mon Jun 13, 2016 3:33 pm Post subject: air |
The first thing to check is to make sure your snot valve is 100% closed and not leaking. Then check for leaks on the banjo fitting on the compressor, crush washers tend to leak sometimes if reused. Also check the line and B nuts for cracks. If the above are tight, and without leaks let me know. I have built up a special test tool to check compressor output. 90% of the time the snot valve is the culprit.
Doug
509-826-4610
On Mon, Jun 13, 2016 at 4:09 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
Any ideas?
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
Dawg
Posted: Mon Jun 13, 2016 3:50 pm Post subject: air |
Snot valve was re-machined several years ago. Pump was replaced at the same time.
I'll check it out.
Thanks.
Sent from my Samsung Galaxy smartphone.
Date:06/13/2016 17:32 (GMT-07:00)
To: yak-list(at)matronics.com
Cc:
Subject: Re: Yak-List: air
Doug
509-826-4610
Any ideas?
FORUMS -
WIKI -
b Site -
rocketerf1(at)yahoo.ca Guest
Posted: Mon Jun 13, 2016 3:55 pm Post subject: air |
On my CJ (if the snot valve is closed) and it starts doing this, it's time to service the air dryer/filter.
Jeff
On Monday, June 13, 2016 5:42 PM, doug sapp <dougsappllc(at)gmail.com> wrote:
Doug
509-826-4610
Any ideas?
FORUMS -
WIKI -
b Site -
Posted: Mon Jun 13, 2016 5:31 pm Post subject: air |
Two suggestions-
Remove the compressor output check valve and clean it thoroughly. You will need new crush washer when reinstalling.
Remove the snot bottle and black flush it with avgas through the input, output and drain fittings. You can submerge it in avgas and shake it around, then drain it. Repeat until what comes out is clear.
Dennis
| Quote: | On Jun 13, 2016, at 7:09 PM, William Geipel <l129bs(at)gmail.com> wrote:
Any ideas?
Viperdoc
Posted: Tue Jun 14, 2016 5:27 pm Post subject: air |
Cleaned the compressor check valve lately? Do you hear an air leak?
Doc
Sent from my iPad
| Quote: | On Jun 13, 2016, at 6:09 PM, William Geipel <l129bs(at)gmail.com> wrote:
Any ideas?
_________________ Viperdoc |
