billhuntersemail(at)gmail Guest
Posted: Thu Jun 30, 2016 4:35 pm Post subject: Composite Aircraft and Lightning Strikes |
Hi All,
There is a discussion brewing on the Velocity Owners Builders Association
about composite aircraft and lightning strikes.
What sparked (sorry) this discussion was a question about static wicks and
if they could be useful on composite aircraft and now there is some good
bantering going on about lightning strikes and composite
aircraft...so...naturally I thought since there is some really sharp
electrical folks on this forum I would ask you all for your feedback on the
subject and I will certainly give you credit for your feedback and
suggestions (of course I could not try to pass this knowledge off as being
my own because that cat is already out of the bag and they would never
believe it came from me).
Anyhoo...here are some questions (if you think up others please feel free to
add):
-Would static wicks be beneficial to add to a composite aircraft?
-If adding static wicks to a composite airplane, where should they be added?
-Should control surfaces be bonded to the aircraft structure if static wicks
are used (and even if static wicks are not used)?
-Should all of the metal components of the aircraft be bonded together and
if so what technique should be employed to do so?
-Does anyone know of any lightning strike incidents to composite aircraft
and if so what damage to the aircraft structure/components have occurred?
-What causes lightning to be attracted to airplanes and/or why does
lightning hit airplanes (yes, I can understand why lightning hits
trees/buildings/other items that are connected to earth but an airplane is
not connected to earth...if it had just taken off I could see the static in
the wake leading to ground however an airplane in cruise flight is another
story)?
-Are composite aircraft more or less likely to be hit by lightning than
metal airplanes?
-Are there any techniques or design considerations that would mitigate the
chance of lightning strikes on the composite aircraft and/or the damage
being done should the aircraft be hit?
-On production composite aircraft, what if any equipment/design
considerations have been required by the FAA to be employed in reducing the
chances of and/or in mitigating the effect of a lightning strike?
-Some guys are discussing using Carbon Fiber or mesh being installed under
the surfaces of the airplane to transfer the energy of a lightning strike so
if a mesh of some sort is indeed used, will it help or hurt in reducing the
chances of and/or in mitigating the effect of a lightning strike (if the
mesh is not robust enough to conduct the extreme electrical current by a
lightning strike could it make the problem worse (as a lightning rod on a
house has a too small conductor then the lightning rod attracts the
lightning and then once the lightning does actually hit the rod the
conductor to ground melts and now the house structure becomes the conduit to
ground)?
Please dream up other thoughts in the area of lightning strikes and I will
certainly forward them on.
We appreciate your help in making the design of the Velocity aircraft more
safe during this time of year!!!
Cheers!!!
Bill Hunter
Posted: Thu Jun 30, 2016 7:44 pm Post subject: Composite Aircraft and Lightning Strikes |
add):
-Would static wicks be beneficial to add to a composite aircraft? |
Depends. A 'static wick' is intended to REDUCE coronal
resistance between CONDUCTIVE parts of the airframe and
the surrounding atmosphere. Without static wicks, electro
static potentials in the millions of volts can build up
in various places on the airframe. The existance of
high levels of static build up can manifest in (1) visible
light (St. Elmo's Fire on prop tips, around window frames,
sharp trailing edges), (2) radio noise that can totally
cripple some systems and sometimes (3) excessive erosion.
The purpose of a static wick is to ENCOURAGE dissipation of
electro-static energies at LOW levels . . . levels too low
to produce the deleterious effects cited.
EXCELLENT question. Figuring out were to put them nn a metal
airplane is not a simple task . . . an insulated airplne is
whole different ball game.
I've seen airplanes perched on insulating jacks and excited
with bunches of volts while a technician walks around the outside
probing potential leak-off points on the airframe with a very
long test probe. This is a good start on figuring out where
potentially
| Quote: | -Should control surfaces be bonded to the aircraft structure if static wicks
if so what technique should be employed to do so? |
Can't think of a single reason to do such things.
I think Burt Rutan may have uttered such an opinion
WAaaayyyy back when about control surfaces on the Ez
series aircraft . . . But I'm at a lost to imagine, much
less demonstrate how the action would benefit anything.
| Quote: | -Does anyone know of any lightning strike incidents to composite aircraft
and if so what damage to the aircraft structure/components have occurred? |
One of our very own suffered just such an event
http://tinyurl.com/hre2hkz
| Quote: | -What causes lightning to be attracted to airplanes and/or why does
story)?
metal airplanes? |
Intuitively one might think so . . . but the airplane
is only a triggering influence in what was going to
be a strike whether the airplane was there or not.
All images of airplanes being struck show the airplane
in the middle of a strike that extends from one
area of the storm (usually cloud) to another area
or the ground.
| Quote: | -Are there any techniques or design considerations that would mitigate the
being done should the aircraft be hit? |
Yeah, it's called staying the (at)#$(at) away from
areas for which no practical invincability can
be demonstrated. This included lightning, ice,
high winds, hail, etc.
| Quote: | -On production composite aircraft, what if any equipment/design
chances of and/or in mitigating the effect of a lightning strike? |
It's exaclty the OPPOSITE. We cannot nor do we attempt
to avoid being struck. We must ASSUME we WILL be struck
and design for measured and predicted stresses.
| Quote: | -Some guys are discussing using Carbon Fiber or mesh being installed under
ground)? |
Check with the Lancair and Glasair forums. These folks
would come a close as anyone to knowing what was tried
and either succeeded or failed to produce the desired
mitigation of effects. There is a wealth of discussion
on . . .
http://tinyurl.com/zeay3x5
. . . this is NOT a trivial task.
| Quote: | Please dream up other thoughts in the area of lightning strikes and I will
safe during this time of year!!! |
History is rife with examples of work done
to make aircraft resistant to the effects of
lightning strike. Lancair, Glassair and contemporaries
wrestled with it. At Beech, we stayed with metal wings
but the fuselage structures have large, flat conductive
straps that run longitudinaly7 in the fuselage. These
'fixes' are tested in direct effects of lightning laboratories
to show that people, structure and systems within the airplane
remain intact after events that are ASSUMED WILL HAPPEN.
The simple answer to the question is: "Yes, you CAN do things
to airplanes of any stripe to reduce risk due to lightning
strike . . . but it's not a simple task. A task deeply intertwined
with issues of structural integrity, weight, aerodynamics . . . and cost.
In flight school, we were well advised to stay away from
ice and convective activity. Risks to body and airframe go
up exponentially . . . while costs for mitigation of those
risks are breathtaking.
Adding any feature intended to mitigate environmental
risk brings some human factor's issues with it. More that
one pilot with boots, prop-deice and a windshield heater
patch was willing to 'press on just a little further' . . .
with more than simply disappointing outcome. The same
effect could beset a pilot flying an airplane with
lightning mitigation enhancements . . . enhancements
that did not benefit from a through checkout in the
lightning lab by folks who have been there, done that.
peter(at)sportingaero.com Guest
Posted: Thu Jun 30, 2016 10:43 pm Post subject: Composite Aircraft and Lightning Strikes |
Before getting really wound up about lightning protection first understand the risk and then figure the mitigation. Look at the accident statistics- how many light aircraft have been struck by lightning and not survived? The answer is very, very few - in the US and in Europe. For whatever reason. Thunderstorms kill many people but lightning does not. My conclusion is that airframe lightning protection is not worthwhile. Thunderstorm protection is difficult so I avoid them.
Peter On 1 Jul 2016 04:50, "William Hunter" <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote: | Quote: | --> AeroElectric-List message posted by: "William Hunter" <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)>
Hi All,
add):
story)?
metal airplanes?
ground)?
Cheers!!!
Bill Hunter
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
glastar(at)gmx.net Guest
Posted: Thu Jun 30, 2016 11:17 pm Post subject: Composite Aircraft and Lightning Strikes |
There is a very narrative report from a glider in the UK, which was hit
by lightning and disintegrated, in the same report a helicopter with
carbon fiber blades is described as well.
http://www.pas.rochester.edu/~cline/ASK%20lightning%20strike/ASK%20accident%20report.htm
For my feeling stay away from possible lightning
Cheers Werner
On 01.07.2016 01:37, William Hunter wrote:
Hi All,
Posted: Fri Jul 01, 2016 3:17 am Post subject: Composite Aircraft and Lightning Strikes |
Read the AAIB report, aircraft was in good VMC. The energy of the strike meant that no protection would have made any difference. The control rods melted - nothing much could be done about that... On 1 Jul 2016 8:30 a.m., "Werner Schneider" <glastar(at)gmx.net (glastar(at)gmx.net)> wrote: | Quote: | --> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)>
There is a very narrative report from a glider in the UK, which was hit by lightning and disintegrated, in the same report a helicopter with carbon fiber blades is described as well.
Cheers Werner
Hi All,
FORUMS -
WIKI -
b Site -
lyleapgmc
Posted: Fri Jul 01, 2016 5:22 am Post subject: Composite Aircraft and Lightning Strikes |
On 6/30/2016 9:04 PM, Robert L. Nuckolls, III wrote:
| Quote: | the problem worse (as a lightning rod on a
Bob . . . |
ROTFLMAO
Posted: Fri Jul 01, 2016 6:07 am Post subject: Composite Aircraft and Lightning Strikes |
At 01:35 AM 7/1/2016, you wrote:
| Quote: | | Before getting really wound up about lightning protection first understand the risk and then figure the mitigation. Look at the accident statistics- how many light aircraft have been struck by lightning and not survived? The answer is very, very few - in the US and in Europe. For whatever reason. Thunderstorms kill many people but lightning does not. My conclusion is that airframe lightning protection is not worthwhile. Thunderstorm protection is difficult so I avoid them. |
Excellent point . . . Similarly, few engines
stop cold because of mechanical or electrical
failure. The majority of 'engine trouble' on
airplanes is fuel exhaustion. The moral of the
story is that the pilot is the weakest link in
the chain of risk for operating an airplane.
Static wicks (also a topic of this thread)
are another matter. They go to a more mundane
issue . . . radio noise and miscellaneous damage
to systems.
The windshields in many high performance airplanes
are vulnerable to the high voltage discharge
often observed around the edges of a window
frame. When that window is fitted with embedded
heater wires, replacement can be VERY expensive.
I thing the price tag on a GP180 window was around
$20K in 1980 dollars.
There have been many experiments with aircraft
finishes and shapes conducted to understand how
static electricity can be better managed on
high performance aircraft.
Not all static wicks are the same. Walk around
the ramp and check out the variations you'll find.
I recall John Cooper, head cheese of our EMC lab
building a fixture to survey static wick performance.
Various samples being tested might vary as much as
3:1 with respect to their 'conductivity'.
Once you identify a 'good' wick design, then finding
the 'right' place to install them was another
grand experiment. And this was on all metal
aircraft. Airplanes of glass and plastic are
another matter. Imagine how you might modify
a glass rod (used to demonstrate static electricity
phenomenon in physics class) to dampen if not
eliminate it's ability to stand up the hairs
on your cat.
Further, your successful technique cannot materially
change structural characteristics, it must be
durable, and it cannot add too much cost.
If anyone discovers some literature
describing successful application of static wicks
to plastic/glass/carbon aircraft . . . I'd REALLY
like to read it.
Posted: Fri Jul 01, 2016 9:24 am Post subject: Composite Aircraft and Lightning Strikes |
Hi All,
THANK YOU FOR YOUR HELP!!! Very good information and I will be passing the information on to the VOBA Forum.
Bill Hunter
+1 408-464-1902 On Jul 1, 2016 7:14 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote: | Quote: | At 01:35 AM 7/1/2016, you wrote:
to systems.
on your cat.
like to read it.
