migfighter42(at)gmail.com Guest
Posted: Thu Jul 07, 2016 12:45 pm Post subject: L29-List: Pylon covers? |
If you are leaving the pylons on but flying with out the fuel tanks, the two ports that are open for pressurization of the tank and the larger line for fuel to the main tank would be left open. The covers for these ports are built into structural provisions in the pylon that hold (via clips) these covers while the tank is in use. not using the covers means you have a bleed air leak (no big deal) but the fuel in from the tank becomes a vent and could pull in debris from ground operations (troubling but unlikely).
I many be able to post a picture later today...
Bill (not THE Bill)
N39DE
Sent from Windows Mail
Sent:�Thursday, July 7, 2016 10:49 AM
To:�l29-list(at)matronics.com
I'm confused about what is being asked about. �When you remove the drop tanks there is a small clip that goes on over the access. As mentioned here. However if you remove the drop tanks and the hard points there are covers that can be put in where the hard points go to make a smooth bottom wing.�
Sent from Yahoo Mail on Android
Quote: | On Thu, Jul 7, 2016 at 10:33, Bill Culberson
<bculberson(at)staraviation.com> wrote:
Specifically,
Clipped on the bottom of the pylon, between the tank and the pylon. When you pull the tank off, you should see them with little clips holing them in some keeper holes. It will fly without them, but not a preferred configuration.
Bill
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of JonSent: Wednesday, July 6, 2016 7:27 PMTo: l29-list(at)matronics.comSubject: Re: L29-List: Pylon covers?
The plug covers are usually clipped to the pylons.
On Jul 6, 2016 8:09 PM, "skidmk" <skidmk(at)gmail.com> wrote:
| - The Matronics L29-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
