schwartzcompany(at)att.ne Guest
Posted: Sat Jul 09, 2016 12:11 pm Post subject: engine won't rotate |
Looking for some ideas. My R model engine won't rotate when I hit start button. Nothing happens . No blade movement whatsoever.
Do not start light out. Three switches at engine all in up position. Removed connector at start box and cleaned it. Nothing. Starter frozen up. Everything else in cockpit works
Any ideas
| - The Matronics L29-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
Posted: Sat Jul 09, 2016 12:14 pm Post subject: engine won't rotate |
Also new batteries fully charged
Sent from Yahoo Mail on Android
Quote: | On Sat, Jul 9, 2016 at 15:11, Robert Schwartz
Do not start light out. � Three switches at engine all in up position. Removed connector at start box and cleaned it. Nothing. Starter frozen up. Everything else in cockpit works
Any ideas
ershire
Posted: Sat Jul 09, 2016 12:34 pm Post subject: engine won't rotate |
Try and rotate the motor with a broom handle. On Jul 9, 2016 4:15 PM, "Robert Schwartz" <schwartzcompany(at)att.net (schwartzcompany(at)att.net)> wrote: Quote: | Also new batteries fully charged
Any ideas
L29delfin(at)yahoo.com Guest
Posted: Sat Jul 09, 2016 12:48 pm Post subject: engine won't rotate |
Blades will turn I tried with a stick
On July 9, 2016 15:36:55 Jon <jonairway(at)gmail.com> wrote: Quote: |
Any ideas
delfin29(at)me.com Guest
Posted: Sat Jul 09, 2016 1:53 pm Post subject: engine won't rotate |
Starting box ?Starter ?
Jean de Roubin Quote: | Le 9 juil. 2016 à 20:34, Jon <jonairway(at)gmail.com (jonairway(at)gmail.com)> a écrit :
Try and rotate the motor with a broom handle. On Jul 9, 2016 4:15 PM, "Robert Schwartz" <schwartzcompany(at)att.net (schwartzcompany(at)att.net)> wrote: Quote: | Also new batteries fully chargedSent from Yahoo Mail on Android
Any ideas
Posted: Sat Jul 09, 2016 2:04 pm Post subject: engine won't rotate |
I'm going to check voltage to start box next. Starter is worst possible problem. Pull engine to look at it
Quote: | On Sat, Jul 9, 2016 at 16:53, delfin29(at)me.com
Jean de Roubin Quote: | Le 9 juil. 2016 à 20:34, Jon <[url=javascript:return]jonairway(at)gmail.com[/url]> a écrit :
Try and rotate the motor with a broom handle. On Jul 9, 2016 4:15 PM, "Robert Schwartz" <[url=javascript:return]schwartzcompany(at)att.net[/url]> wrote: Quote: | Also new batteries fully chargedSent from Yahoo Mail on Android
Any ideas
Posted: Sat Jul 09, 2016 2:15 pm Post subject: engine won't rotate |
Any ideas
sd737(at)aol.com Guest
Posted: Sat Jul 09, 2016 2:37 pm Post subject: engine won't rotate |
Probably start button in cockpit panel. Cleaning cannon plug won't do much.
Or.....
Pull tail and remove power cable from start box and momentarily put power directly to starter cable lead and see if you get rotation.
Dawg
Posted: Sat Jul 09, 2016 5:07 pm Post subject: engine won't rotate |
I agree with Scott. If the starter is bad you would still hear something. Start box is pretty reliable.
Or.....
Pull tail and remove power cable from start box and momentarily put power directly to starter cable lead and see if you get rotation.--
_________________ Dawg |
