Markus
Posted: Tue Aug 30, 2016 11:52 pm Post subject: excessive loss of oil during aerobatics |
Hello all,
Last weekend I noticed an excessive loss of oil during aerobatics in our Extra (AEIO-580). Up to now we where using about 0.5-1 quart per hour of aerobatics, but last weekend that raise to around 4 quarts per hour (5 displays of around 15min each at an airshow). There is no visible (read "more then usual") oil coming from the cowling/firewall and I believe that if the engine oil would be burned by the engine (broken oil rings, bad valve guide or so) that there would be a noticable smoke trail coming from the exhaust with that amoutn of oil being lost!?
However, in one short video sequence I saw that after a negative push to the vertical there was quite a trail of oil coming from the engine breather hose, which I haven´t noticed in previous flights (at least not as intense as in that clip). I´m now suspecting the shuttle valve/air-oil separator...
Any hints, tips, tricks or suggestions?
Should I just remove both the shuttle valve and air-oil separator and clean/flush it with mineral spirits/petroleum?
Anything else to be aware of?
Thanks and best regards,
Markus
| | - The Matronics Aerobatic-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Aerobatic-List |
