Dynamic Balancing in the NW
threein60
PostPosted: Mon Jul 18, 2016 12:16 pm    Post subject: Dynamic Balancing in the NW Reply with quote
There has been a lot of issues with getting dynamic propeller balancing here in the upper NW area. Since the shop at AWO has closed up, and other local shops can be weeks out before openings (even if they accepted round engines) - I will offer my services. I am an A&P/Avionics Engineer for the last 21 years. I have a Dynavib GX2. I am able to dynamically balance propellers as well as provide a spectrum analysis of engine/airframe vibrations for both certified as well as Experimental aircraft. This is very helpful in locating issues when your prop has been both statically as well as dynamically balanced and you still are experiencing vibrations. I am based out of AWO but can travel within reason. If interested please contact me at 480-544-2244. Larry
