phil(at)hdmnet.com Guest
Posted: Mon Aug 01, 2016 3:36 pm Post subject: Aux power to learn avionics |
Forgive my naive question which has probably been addressed before on this list. I did search before posting.
I have purchased a 2001 Cessna T182T. To learn all the systems on the ground I purchased a Schauer JAC2024H battery charger from Aircraft Spruce, with the typical Cessna plug for external power.
I hooked it up, turned on the charger, turned on master, then avionics and sat there studying for a bout 10 minutes when I noticed that the battery voltage was graducally dropping. I fear I was actually draining the main battery which is getting close to replacement time.
Am I doing something wrong?
I have also purchased a battery minder for continuous, low voltage charging to keep the battery healthy. Advise will be much appreciated.
Phil Hooper
President
Harvest Development & Media Inc.
19851 Yorba Linda Blvd., Suite 204
Yorba Linda, CA 92886
voice: 714.693.8745
fax: 714.777.0134
web: http://www.hdmnet.com/
email: phil(at)hdmnet.com (phil(at)hdmnet.com)
Joined: 28 Mar 2008 Posts: 1969 Location: Riley TWP Michigan
Posted: Mon Aug 01, 2016 3:52 pm Post subject: Re: Aux power to learn avionics |
I do not know why, but Aircraft Spruce's description says,
| Quote: | | "Not intended for use as a DC power supply." |
Without knowing how the Cessna is wired, all I can suggest is to connect the charger directly to the battery to see if that makes a difference.
_________________ Joe Gores |
Posted: Mon Aug 01, 2016 4:04 pm Post subject: Aux power to learn avionics |
The system that you had turned on was drawing more than the 20 amps that the charger was able to produce.
If you are going to run your stuff for an extended period, you need a power supply capable of mainlining a set voltage with the amount of current flowing.
In my RV6A, I can use a good portion of my avionics with a 30 AMP power supply and maintain voltage sufficient to not discharge the battery.
Right or wrong is not the answer here - with a 20A charger, you have too much stuff turned on for the charger to keep up.
rampil
Posted: Wed Aug 03, 2016 5:51 am Post subject: Re: Aux power to learn avionics |
BTW, Batteries are made to be drained!
No harm, no foul! You just need to recharge your lead acid battery
when you are done studying. Discharging your battery to the point where
your avionics quits (probably about 10 volts(here I am guessing that the avionics is universal 12-24 compatible)) will not harm the battery.
Some avionics (with poor design) may complain more.
And yes, The voltage was probably declining due to current draw in
excess of charger supply
