ground aerobatics...
Herbgh(at)nctc.com
PostPosted: Tue May 03, 2016 6:44 pm    Post subject: ground aerobatics... Reply with quote
Seems that Herb cannot get anything right today...been that kind of
day....!! anyhow...the Test flight video of the Firefly(for those of
you who have been following this saga) was the second flight...The same
guy,experienced Kolb owner, flew a no video ,by the book first
flight...testing trim, stall so on...
Satisfied the strapped on the camera and did the you tube
flight....and the third flight was the owner flipping the plane on its
back.. private , non accessible video at this time..
clear as mud? Herb
On 05/03/2016 07:58 PM, pcking wrote:
That the pilot flies sailplanes could explain what you see as extreme
maneuvers in the video. A 45 degree bank is normal in a sailplane when
you are trying to fly in the core of a thermal. A pullup to wings
vertical is a fast way to reverse direction when you have flown out of
the core. This pilot found himself in a plane with a crisp roll rate
and enjoyed it.
victorbravo(at)sbcglobal.
PostPosted: Tue May 03, 2016 11:20 pm    Post subject: ground aerobatics... Reply with quote
Now it's clear... I did not realize the new owner had wrecked it. The youtube videos I saw did not show anything that frightened me... I'm an old washed up 15 meter glider racer myself Smile
Bill Berle
On Tue, 5/3/16, Herb <Herbgh(at)nctc.com> wrote:
Subject: ground aerobatics...
Date: Tuesday, May 3, 2016, 7:44 PM
kind of
flight...The same
first
plane on its
   clear as mud?   Herb
see as extreme
sailplane when
pullup to wings
have flown out of
crisp roll rate
> and enjoyed it.
flywithme
PostPosted: Fri May 06, 2016 8:48 am    Post subject: Re: ground aerobatics... Reply with quote
i see in some posts reference to the first pilot making a steep banking turn as being a dangerous maneuver in a kolb. is this really such a dangerous maneuver
PostPosted: Fri May 06, 2016 10:17 am    Post subject: ground aerobatics... Reply with quote
By normal flight training standards, based on very old memories, a steep turn is one that uses a bank angle 45 degrees or higher. 60 degrees is considered the "steep turn" benchmark when you do FAA private pilot training (at least it was in the 1970's when we had real pilot training).
A 60 degree banked level flight turn in calm air results in exactly a 2G load on the airframe. I'm pretty sure that the Kolb was designed to withstand far far more than 2G. (if not, I have a Firestar kit for sale cheap).
However, bank angle alone does not determine G forces. A 60 degree banked coordinated level flight turn will give you 2G. But a "wingover" maneuver is not a level turn, and most of the time the high bank angle comes at a time when the airplane is "unloaded". So the reality is that the wingover maneuver shown in the video could easily have been at ZERO-G. (I do zero-G wingovers all the time in an old Cessna 172 and it puts zero stress on the airframe)
You can do a simple "aileron roll" that puts no stress whatsoever on the airplane for 3/4 of the maneuver, and only 1.3 or 1.4G on the airplane during the other 1/4 of the maneuver. There is a very famous incident of a Boeing test pilot named Tex Johnson doing a full 360 degree aileron roll in the first prototype 707, with a bunch of news reporters on board, and it didn't even ruffle anyone's hair on board the airplane. You can find the video on youtube I'm sure.
The FAA definition of "Aerobatics" is an excursion from level flight of more than 30 degrees of pitch and 60 degrees of bank. But "aerobatic" maneuvers can easily be done that exceed these numbers without putting any abnormal stress or loads on the airplane... and are in reality not "dangerous" in any way. What gets dangerous is when the pilot misjudges or mishandles the recovery from these maneuvers, and can easily accidentally exceed the speed or G load limits that the airframe can handle. THAT is the dangerous part, and THAT is why any pilot with a brain in his head will get aerobatic or "upset recovery" training before playing around with these kinds of maneuvers.
The Kolb was of course not designed for aerobatics. It does not make any sense to do intentional aerobatics in a Kolb. As mentioned by others, if you are going to go out and do hard aerobatics on purpose then go rent a Citabria.
Bill Berle
On Fri, 5/6/16, flywithme <constrjh(at)pldi.net> wrote:
Subject: Re: ground aerobatics...
Date: Friday, May 6, 2016, 9:48 AM
"flywithme" <constrjh(at)pldi.net>
http://forums.matronics.com/viewtopic.php?p=455928#455928
Forum -
   - MATRONICS WEB FORUMS -
MATRONICS LIST WIKI -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
PostPosted: Fri May 06, 2016 4:50 pm    Post subject: ground aerobatics... Reply with quote
I can only speak for myself. My Kolbs all loved to fly that way. To me, it
was/is normal.
The Kolb is a very capable aircraft, but to fly it well, one needs to train
and practice, practice, practice.
I am out of shape now. When I go out to fly, I ease myself into more
demanding maneuvers as I get reacquainted with my airplane.
UltrastarFlyer
PostPosted: Tue Aug 02, 2016 6:26 pm    Post subject: Re: ground aerobatics... Reply with quote
Boy here you go again... Not even close.
FAR 91.303
"...For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight."
Maybe you were confused with the FAR that requires parachutes?
Just because you have a computer doesn't give you the right to fabricate or worse, misquote regulations. Please consider there are many new pilots here that are impressionable and unfortunately might take your nonsense as fact or law. It's your responsibility to ONLY post fact. If you don't know then use words like " I think" or "I don't know". To continue to do otherwise is disingenuous and irresponsible.
Just sayin...
Bill Berle
"flywithme" <constrjh>
Forum -
              -Matt
Dralle, List Admin.
1984 Kolb Ultrastar
Cuyuna ULII-02
Ultraprop
252 lbs
UltrastarFlyer
PostPosted: Tue Aug 02, 2016 6:32 pm    Post subject: Re: ground aerobatics... Reply with quote
FAR 91.303
Just sayin...
Bill Berle
Forum -
              -Matt
Dralle, List Admin.
1984 Kolb Ultrastar
Cuyuna ULII-02
Ultraprop
252 lbs
Richard Pike
PostPosted: Wed Aug 03, 2016 5:53 am    Post subject: Re: ground aerobatics... Reply with quote
To Ultrastarflyer: I have noticed that you are fairly new to the list, and that you have several recent double posts - a second identical post a couple minutes after the first.
This list server is often very slow to update. When you push the "Submit" button, go get a cup of coffee or find something else to do for a bit. It will eventually get posted. You don't need to get impatient and submit it again.
Shalom
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Wed Aug 03, 2016 9:26 am    Post subject: ground aerobatics... Reply with quote
What's going on here, Crankpot? Did I take your parking spot at the grocery store, or did I steal your bike when we were kids or something?
I'd like to understand what has made you irritated enough with me that you go back over two months (May 6) on this list, and find something that I wrote (in response to a completely different subject), and then try to lambaste me over it as if I was spreading false information. FIRST, let's address the inference that I am spreading false or misleading information, and harming innocent new pilots in the process:
91.303 may indeed say that "For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an
aircraft's attitude..." and I accept that that definition of aerobatics exists in the FAR (or 14CFR nowdays).
BUT... as you yourself pointed out... there is also ANOTHER definition of aerobatics that is directly relevant to what I had mentioned.
Take a look at this description from EAA where they reference the FAR 91.307 aerobatics
https://www.eaa.org/en/eaa/aviation-communities-and-interests/homebuilt-aircraft-and-homebuilt-aircraft-kits/frequently-asked-questions/parachutes-during-aerobatics
I believe you will find that IN ADDITION to the one regulation you are hanging your argument on, another equally valid regulation mentions parachutes and aerobatics in reference to the 60 degrees of bank and 30 degrees of pitch that I had mentioned in my post.
So, here is a way to validate your argument, and perhaps you can make me look like an idiot in the process... Have 10 instructors read BOTH of the FAR sections that have been referenced here. The one that says "... abrupt change..." and the one that says "... a bank exceeding 60 degrees..." Ask these instructors if they think the FAA considers over 60 degrees of bank an aerobatic maneuver or not.
If the majority of those instructors say "No, a bank of over 60 degrees or pitch angle over 30 degrees is not an aerobatic maneuver", then I'm an idiot and my opinion posted on this list back in May was wrong.
Now, back to the larger problem. Have the guts to explain exactly what it is that I have done, said, written, or thought that has made you dislike me enough to have tried to skewer me on this list when I have not done any such thing to you. Is it the color of my skin, my religion, my politics? Have we met someplace before and I was a jackass to you? You have every right to like or dislike me at your discretion, but just as pilots have a responsibility to not spread BS you have a responsibility to stand behind your statements and/or your dislike for me.
Bill Berle
Kolb Firestar 2
Cessna 172
Los Angeles
Date: Tuesday, August 2, 2016, 7:26 PM
"UltrastarFlyer" <Crankpot(at)gmail.com>
FAR 91.303
parachutes?
irresponsible.
Just sayin...
training).
> Bill Berle
> www.ezflaphandle.com  - safety & performance
upgrade for light aircraft
> www.grantstar.net           - winning
proposals for non-profit and for-profit entities
>  To: kolb-list(at)matronics.com
>  "flywithme"
making a
in a kolb.
>  Read this topic online here:
>  Forum -
>                -Matt
>  Dralle, List Admin.
1984 Kolb Ultrastar
Cuyuna ULII-02
Ultraprop
252 lbs
http://forums.matronics.com/viewtopic.php?p=459136#459136
Forum -
              -Matt
Dralle, List Admin.
PostPosted: Wed Aug 03, 2016 9:54 am    Post subject: ground aerobatics... Reply with quote
Why don't you two take your differences back copy. I'm not interested and pretty sure no one else is. If there are those on the List that are interested, they can join you all back copy also.
PostPosted: Wed Aug 03, 2016 10:31 am    Post subject: ground aerobatics... Reply with quote
John H and Kolbers, I have no quarrel or difference with this person. Don't even know how he is. I have no idea what I did that made him upset, and I will apologize if I owe one. But instead of offline or back copy, he more or less called my integrity into question here on the main list. The only thing I have done is address his challenges directly, and to be honest I used some amount of restraint.
1) Perhaps the Kolb list participants who have read both of these exchanges between he and I can comment on whether they think my responses have been appropriate or not, and whether it is Crankpot or myself that needs some more dual instruction.
2) If the members of this list and/or the forum administrator feel that Crankpot was within his rights and privileges to fire a shot across my bow, but I am not within my rights or privileges to fire back, then let me know that too, and I will "govern myself accordingly" to quote another famous aviation internet forum.
Bill Berle
On Wed, 8/3/16, John Hauck <jhauck(at)elmore.rr.com> wrote:
Subject: RE: Re: ground aerobatics...
Date: Wednesday, August 3, 2016, 10:53 AM
"John Hauck" <jhauck(at)elmore.rr.com>
PostPosted: Wed Aug 03, 2016 11:10 am    Post subject: ground aerobatics... Reply with quote
Why don't you knock this crap off.
I am respectfully asking you and your buddy to play this game somewhere else besides the Kolb List.
I'm too old to waste my time deleting this crap.
I may be the only one that does not appreciate the conflict between you two, but I am expressing my request.
This is a List for building and flying Kolb aircraft. This is not the place to settle pissing contests.
john h - Never gotten above the rank of member in 18.5 years. Wonder why?
Bill Berle
ceengland7(at)gmail.com
PostPosted: Wed Aug 03, 2016 11:24 am    Post subject: ground aerobatics... Reply with quote
Well, to start, you could set a good example by voicing your complaints
privately to both individuals, instead of posting it to the entire list. Wink
This is a more or less open list. If you don't like an open format, you
could start a closed, censored forum like those of us who fly RV's are
forced to live with on VAF. While you might prefer that format, those of
us who enjoy thinking for ourselves and being able to speak our thoughts
prefer the more open format we have here.
Bill,
I can totally understand & support your need to respond to Crankpot, but
I'm reminded of the old saw about getting in the mud with a pig.
Bill Berle
lcottrell
PostPosted: Wed Aug 03, 2016 11:41 am    Post subject: ground aerobatics... Reply with quote
I second that emotion, all in favor- say aye!Larry
On Wed, Aug 3, 2016 at 1:09 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
--> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
Bill Berle
The older I get, the less tolerant I am of those who are intolerant of others.
PostPosted: Wed Aug 03, 2016 12:01 pm    Post subject: ground aerobatics... Reply with quote
I have sent an e-mail asking the forum owner/administrator for his opinion on this apparent conflict. His opinion will carry the most weight with me.
I'm pretty sure that my responses to Crankpot on these two discussion threads were more restrained than his original posts.
Once again I'll offer an apology to anyone I accidentally offended, although I don't make a habit of allowing people to poke at me with impunity... especially when I was not the aggressor in either exchange.
Bill Berle
On Wed, 8/3/16, Larry Cottrell <lcottrell1020(at)gmail.com> wrote:
Subject: Re: Re: ground aerobatics...
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Date: Wednesday, August 3, 2016, 12:41 PM
I second that
1:09 PM, John Hauck <jhauck(at)elmore.rr.com>
years.  Wonder why?
instruction.
Bill Berle
-List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?Kolb-List
eferrer"
target="_blank">http://forums.matronics.com
errer"
target="_blank">http://wiki.matronics.com
rel="noreferrer"
The
If you forward this email, or any part of
it, please remove my email address before sending.
williamtsullivan(at)att.n
PostPosted: Wed Aug 03, 2016 12:13 pm    Post subject: ground aerobatics... Reply with quote
For all of the new people on the List, it is customary to delete previous info from a reply. Leave just enough so that the conversation can be followed. If you just make a comment without any future research content, please put "do not archive" in the message, so it doesn't clog the servers.
Bill Sullivan
This
years.  Wonder why?
wrk2win4u
PostPosted: Wed Aug 03, 2016 12:28 pm    Post subject: ground aerobatics... Reply with quote
�� Aye!
On Aug 3, 2016, at 13:45, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
I second that emotion, all in favor- say aye! Larry
Bill Berle
