art(at)zemon.name Guest
Posted: Thu Aug 25, 2016 3:29 am Post subject: Connectors for Wing Roots |
From the The-Nice-Thing-About-Standards-Is-There-Are-So-Many-To-Choose-From Department:
I need to choose the connectors to use at the wing roots of my BD-4C. The wings will come off annually for inspection, which means at least one cycle per year for these connectors. There was a thread here recently about Molex connectors being good for long term use but not designed for many operational cycles. That has me shying away from Molex because I don't understand the failure mode, especially how to recognize a connector that is nearing end-of-life.
The AMP CPC series looks solid but seems kind of pricey for a device that I need to operate just once per year
http://www.aircraftspruce.com/categories/aircraft_parts/ap/menus/el/cablecableaccessories_cpc.html
Is that CPC right choice? Is there something else that you would recommend?
I need 9 pins in the left wing. 2 (at) 10 amps and all of the others are low current.
I need 6 pins in the right wing, all low current.
-- Art Z.
http://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
bob.verwey(at)gmail.com Guest
Posted: Thu Aug 25, 2016 4:13 am Post subject: Connectors for Wing Roots |
handshake connectors
On Thursday, 25 August 2016, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
| Quote: | From the The-Nice-Thing-About-Standards-Is-There-Are-So-Many-To-Choose-From Department:
-- Art Z.
Best...Bob Verwey
Posted: Thu Aug 25, 2016 4:56 am Post subject: Connectors for Wing Roots |
Bob,
Do you mean these things: http://www.elliottelectronicsupply.com/connectors/crimp-solderless-terminals/insulated/hand-shake-connectors.html
Those look like something to use in lieu of a splice, not something to be disconnected/reconnected when the wing is removed for inspection and reinstalled after the annual.
-- Art Z.
On Thu, Aug 25, 2016 at 7:11 AM, Bob Verwey <bob.verwey(at)gmail.com (bob.verwey(at)gmail.com)> wrote:
| Quote: | handshake connectors
-- Art Z.
Best...Bob Verwey
ceengland7(at)gmail.com Guest
Posted: Thu Aug 25, 2016 6:12 am Post subject: Connectors for Wing Roots |
-- Art Z.
http://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
| Art,
My go-to connector is almost always the standard sub-D, using crimp style machined pins. For the 10A loads, just parallel a pair of pins using 6" pigtails (details in the book). They've been around for decades, any number of pins you would reasonably need (pick a shell with a half dozen extra slots for future expansion), they are rock solid reliable (gold plated pins), reasonably priced, common affordable installation tools (that you'll need for your avionics, anyway), and you can find them almost anywhere. As long as you don't position them in a steady stream of water, they should be great.
Charlie
kjashton(at)vnet.net Guest
Posted: Thu Aug 25, 2016 6:44 am Post subject: Connectors for Wing Roots |
For wing connectors, there is always something suitable at the FLAPS. I use a 4-wire round rubber connector that is pretty water resistant. Flat trailer connectors would work. For a show-horse, Anderson Powerpole.
-Kent
Posted: Thu Aug 25, 2016 8:51 am Post subject: Connectors for Wing Roots |
Indeed! Art they are very reliable. slip a piece of clear tubing over each joint and cable tie to keep in place. SOP for many OEM's
| Quote: | Bob,
-- Art Z.
On Thu, Aug 25, 2016 at 7:11 AM, Bob Verwey <[url=javascript:_e(%7B%7D,'cvml','bob.verwey(at)gmail.com');]bob.verwey(at)gmail.com[/url]> wrote:
On Thursday, 25 August 2016, Art Zemon <[url=javascript:_e(%7B%7D,'cvml','art(at)zemon.name');]art(at)zemon.name[/url]> wrote:
-- Art Z.
Best...Bob Verwey
Best...Bob Verwey
Posted: Thu Aug 25, 2016 10:25 am Post subject: Connectors for Wing Roots |
... woops... and Charie.
-- Art Z.
DB connectors and trailer light connectors. Two good suggestions. Thank you, Bob & Bob.
-- Art Z.
ashleysc(at)broadstripe.n Guest
Posted: Fri Aug 26, 2016 8:31 am Post subject: Connectors for Wing Roots |
Not familiar with "handshake connectors." Please amplify and provide mfg. and pt. no.
Cheers! Stu.
Sent: Thursday, August 25, 2016 5:11:48 AM
Subject: Re: Connectors for Wing Roots
-- Art Z.
Best... Bob Verwey
Posted: Sat Aug 27, 2016 1:18 pm Post subject: Connectors for Wing Roots |
On Sat, Aug 27, 2016 at 3:35 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 11:30 AM 8/26/2016, you wrote:
| Quote: | Not familiar with "handshake connectors." Please amplify and provide mfg. and pt. no.
Cheers! Stu. |
Here is one modern incarnation of a T&B terminal
we used to use on the Cessna twin engine line.
As you can see, they're not cheap. They're certainly
secure in tension . . . but no more so than a
knife splice.
I've got some 40 year old wrist-locks around here
somewhere . . . shows you how often I've been
excited about using them.
In addition to being pricey, anything like that (knife splice, etc) still has the downside of requiring an operation for each wire whenever they must be disconnected, and they require some other ID for each wire pair to ID them for re-connection, with a risk of error still there. With a multi-pin, keyed connector, one operation and no risk of connection error.
Posted: Sun Aug 28, 2016 9:27 am Post subject: Connectors for Wing Roots |
The Matronics server seems to no longer allow
embedded images. Here's a re-post of my comment
along with a link to the picture
Cheers! Stu. |
knife splice.
http://tinyurl.com/z5nx9h3
raymondj(at)frontiernet.n Guest
Posted: Sun Aug 28, 2016 10:17 am Post subject: Connectors for Wing Roots |
The picture and the table of prices came through to me in email.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 08/28/2016 12:17 PM, Robert L. Nuckolls, III wrote:
| Quote: | The Matronics server seems to no longer allow
> mfg. and pt. no.
> Cheers! Stu.
knife splice.
Posted: Sun Aug 28, 2016 11:19 am Post subject: Connectors for Wing Roots |
Bob,
Same here. However, when I tried to reply to that email (the reply
included the images from your original post), the Matronics server
rejected my reply. I then deleted the images from my reply, and the
server accepted it.
That's not the 1st time it's happened to me in replying to one of your
emails that had embedded images, so apparently it must alter something
in the image when it 'broadcasts' the original email, and the resultant
altered image isn't allowed to come back into the server.
Charlie
On 8/28/2016 1:13 PM, rayj wrote:
Raymond Julian
Kettle River, MN
honesty, understanding and feeling are the concomitants of failure in
our system. And those traits we detest, sharpness, greed,
acquisitiveness, meanness, egotism and self-interest are the traits of
success. And while men admire the quality of the first they love the
produce of the second. -John Steinbeck, novelist, Nobel laureate
(1902-1968)
>> mfg. and pt. no.
>> Cheers! Stu.
> knife splice.
> Bob . . .
Posted: Sun Aug 28, 2016 7:28 pm Post subject: Connectors for Wing Roots |
Hi Bob;
I think the "wristlock" is different than the "handshake," but seem to do the same function. Thanks; I didn't know about wristlock either.
Cheers! Stu.
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Sunday, August 28, 2016 10:17:59 AM
Cheers! Stu. |
knife splice.
[url=http://tinyurl.com/z5nx9h3][/url] I've got some 40 year old wrist-locks around here
Posted: Mon Aug 29, 2016 6:52 am Post subject: Connectors for Wing Roots |
Hi Bob;
Yes, I believe you have illustrated the handshake. Is it less colloquially called a knife splice?
Cheers! Stu.
Sent: Monday, August 29, 2016 6:07:47 AM
At 10:27 PM 8/28/2016, you wrote:
| Quote: | Hi Bob;
Cheers! Stu. |
Oh . . . I've not seen the "handshake" colloquialism applied to terminals before . . . but it seems to
make sense for knife splices.
Is this a 'handshake' terminal? Need to keep
my hangarspeak dictionary up to date!
Posted: Mon Aug 29, 2016 7:16 am Post subject: Connectors for Wing Roots |
At 09:51 AM 8/29/2016, you wrote:
| Quote: | Hi Bob;
Cheers! Stu. |
Interesting question. A google search
on 'knife splice' yielded 390,000
hits; 'hand shake splice' yielded
only 151,000 hits. But in spite of
my own ignorance for the use of
'hand shake' . . . it's obviously
in wide spread use.
I can go to bed tonight knowing
something that I did not know this
morning . . . it's a good day!
Posted: Mon Aug 29, 2016 8:14 am Post subject: Connectors for Wing Roots |
Question regarding both the knife/handshake and wristlock connectors.
Do they achieve the high pressure connection that the spade terminals
achieve? Aside from electrically insulating them from the environment
should any additional steps be taken to "seal them in"? I'm thinking of
dielectric grease coating under shrink seal, or even better, adhesive
filled shrink seal.
Raymond Julian
Kettle River, MN
On 08/29/2016 10:15 AM, Robert L. Nuckolls, III wrote:
| Quote: | At 09:51 AM 8/29/2016, you wrote:
> Hi Bob;
> Cheers! Stu.
in wide spread use.
Posted: Mon Aug 29, 2016 12:59 pm Post subject: Connectors for Wing Roots |
At 11:13 AM 8/29/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net>
Question regarding both the knife/handshake and wristlock connectors. Do they achieve the high pressure connection that the spade terminals achieve? Aside from electrically insulating them from the environment should any additional steps be taken to "seal them in"? I'm thinking of dielectric grease coating under shrink seal, or even better, adhesive filled shrink seal.
Ordinary heat-shrink keeps them engaged and
free of incidental contamination. It's been
done this way on TC aircraft forever . . .
did it on B52s in 1960 except we had
soft vinyl tubing with string ties on both
ends . . . the era before heat-shrink.
The purpose of this kind of joint is SERVICEABILITY,
ease of opening single strands for maintenance.
They've proven quite adequate to the task
for decades.
