VOR/LOC/GS BALUN Fabrication
haribole
PostPosted: Fri Sep 16, 2016 4:38 pm    Post subject: VOR/LOC/GS BALUN Fabrication Reply with quote
Meant to include the link:
http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html
On Fri, Sep 16, 2016 at 8:35 PM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
Hello Group
I was trying to fabricate this cable, but having trouble in step 2. The exposed braid refuses to suck up the molten solder. The moment I put a soldering iron ( a standard radio shack 35W iron) the solder freezes up and won't melt and flow. Have enough flux applied to the braid, not sure what I can do to get this tinned.
any pointers would be highly appreciated
Hari
haribole
Hello Group
Hari
PostPosted: Fri Sep 16, 2016 6:16 pm    Post subject: Re: VOR/LOC/GS BALUN Fabrication Reply with quote
What kind of solder are you using? Some types melt at a higher temperature. The wire might not be getting hot enough or made of a metal that does not readily accept solder. What kind of flux are you using? Solder made for electrical connections usually has a flux core and extra flux is not needed. Flux made for plumbing is acid based and will cause electrical connections to corrode and fail eventually.
Joe Gores
ceengland7(at)gmail.com
PostPosted: Sat Sep 17, 2016 5:45 am    Post subject: VOR/LOC/GS BALUN Fabrication Reply with quote
Can you attach a pic of your actual setup (coax, iron, solder, etc)?
Misc thoughts: Iron tip must be clean & tinned with solder, for efficient heat transfer to the work. Also, some 35W irons have very low mass tips, and can't keep up with the heat transfer into a large 'sink' like braid. 60/40 or 63/37 rosin core electronics solder; Electronics grade flux; and last, this is a long shot, but make sure your coax is copper braid shield and not a foil shield. There are some coaxes that have an aluminum foil shield instead of braided copper.
On Fri, Sep 16, 2016 at 7:35 PM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
Hello Group
Hari
haribole
PostPosted: Sat Sep 17, 2016 9:39 am    Post subject: VOR/LOC/GS BALUN Fabrication Reply with quote
I was putting in the cable for a new build and after reading the description again, postponed this till I actually test the performance.Thanks to all for the pointers.
On Sat, Sep 17, 2016 at 9:43 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Hello Group
Hari
