Fuel tank
N456TS
PostPosted: Wed Sep 21, 2016 10:27 am    Post subject: Fuel tank Reply with quote
Does anyone know what coating, if any, is used for the Allegro fuel tank? It's red in color and appears to be a hard, epoxy-like coating.
N456TS
doug(at)allegrolsa.com
PostPosted: Thu Sep 22, 2016 7:10 am    Post subject: Fuel tank Reply with quote
The newer Allegro ( of which, yours is one) had a coating made by the Bill
Hirsch company. It is an Alcohol/Ethanol resistant gas tank sealer. Please
let me know if you need any additional information.
Doug
Douglas Hempstead
LSA America, Inc.
231 US Hwy 158 East
Littleton, NC 27850
252-586-1200 - office
252-586-1203 - fax
www.allegrolsa.com
N456TS
PostPosted: Mon Sep 11, 2017 12:00 am    Post subject: Re: Fuel tank Reply with quote
Hi Doug.
I have been looking into the tank liner made by Bill Hirsch. It appears that their liner is white in color. The inside of my tank is red. This leaves me unsure of what is/isn't in that fuel tank. Did my tank not get coated when it was built?
Bradley
N456TS
PostPosted: Mon Sep 11, 2017 6:44 am    Post subject: Fuel tank Reply with quote
Bradley,
Thank you for your note. ALL Allegro fuel tanks are coated, including
N456TS. I will go back to the records to check exactly which coating was
used. I can say that ALL our fuel tank coatings were resistant to ethanol
AND were fully capable of handling up to 10% ethanol fuel.
We are in process of sending out a service bulletin for non-ethanol fuels.
We have found that non-ethanol fuels are not regulated as to additives. In
some cases MEK is used as an additive. MEK, over time, CAN break down the
coating and attached the composites. The service bulletin will require
either NOT using non-ethanol fuels, or KNOWING there is no MEK used in the
additives.
Hope this helps.
Doug
Douglas Hempstead
LSA America, Inc.
231 US Hwy 158 East
Littleton, NC 27850
252-586-1203 - fax
www.allegrolsa.com
