Stitching Baffle Seals
philperry9
PostPosted: Thu Sep 29, 2016 6:31 pm    Post subject: Stitching Baffle Seals Reply with quote
I've got a couple of baffle seals that don't cooperate around my prop gov.  And since I just removed and replaced by MT gov, I'd like to go ahead and clean up the baffle seals.
Where two of my seals intersect, I'd like to bond them together.  I've tried pro-sealing them, but it didn't hold.   So I need a mechanical bond and I'm considering stitching them.
Has anyone tried stitching them and if so, what material did you use for thread?
Phil
gengrumpy
PostPosted: Thu Sep 29, 2016 6:42 pm    Post subject: Stitching Baffle Seals Reply with quote
Just stitch them together with some lacing materiel….can get that thru Spruce if you don’t have any, and big needles from a sewing supply place.
grumpy
Phil
jmjones2000(at)mindspring
PostPosted: Fri Sep 30, 2016 1:43 am    Post subject: Stitching Baffle Seals Reply with quote
Phil,
If you have the Orange baffle seals, they are made of silicone. Get the Red RTV and glue them together. It will hold if the surfaces are cleaned with isopropyl or denatured alcohol prior to application. If you'd like to hold it together mechanically, stitching with Dacron lacing tape or riveting with appropriately sized washers on either side will work. Be sure to put silicone (red RTV looks best) in between the seals before mechanically holding them together for an air tight seal.
Justin
Phil
Ben Meyer
PostPosted: Fri Sep 30, 2016 2:21 am    Post subject: Stitching Baffle Seals Reply with quote
Safety wire worked for me.
Ben
Phil
Mauledriver(at)nc.rr.com
PostPosted: Fri Sep 30, 2016 6:43 am    Post subject: Stitching Baffle Seals Reply with quote
I'd second that on the silicone seals. After 5 years and 700+ hours they
are still almost like new including the high temp red/orange RTV. No
mechanical stiching required.
Justin
> Thanks,
> Phil
rene(at)felker.com
PostPosted: Fri Sep 30, 2016 6:59 am    Post subject: Stitching Baffle Seals Reply with quote
I used safety wire in  one or two of my corners….sealed with Red RTV.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Thursday, September 29, 2016 8:27 PM
Subject: Stitching Baffle Seals
Phil
