Marking acrylic windscreen
philperry9
PostPosted: Thu Oct 13, 2016 7:49 am    Post subject: Marking acrylic windscreen Reply with quote
Before I do something I regret with a sharpie, does anyone know if it's safe to use directly on the windscreen?
Or, is there an alternative that I could utilize?
I'm looking to fair in the windscreen and need to mark the windscreen with the 7" radius so I can lay the electrical tape down.
Phil
carl.froehlich(at)verizon
PostPosted: Thu Oct 13, 2016 9:07 am    Post subject: Marking acrylic windscreen Reply with quote
No. Do not do it unless you are marking a line that will get cut out. If
you want to make a radius, just use the edge of the tape. No need to mark
to do this.
Carl
Lenny Iszak
PostPosted: Thu Oct 13, 2016 12:48 pm    Post subject: Re: Marking acrylic windscreen Reply with quote
You can use 1/4 vinyl masking tape like this: https://amzn.com/B00IOQ3J9Q
Lenny
