philperry9
Posted: Fri Oct 14, 2016 8:30 am Post subject: Another windscreen Q |
Has anyone had success only mechanical etching the upper fuse with sandpaper vs acid etching? (When prepping for the windscreen to be faired in)
I'd really like to avoid chemically etching that area as I have lots and lots of cash sitting directly below that area in my panel and also already have the windscreen secured in place with Weld-On.
Just collecting info before I proceed.
Phil
rv10flyer(at)live.com Guest
Posted: Fri Oct 14, 2016 8:44 am Post subject: Another windscreen Q |
My whole plane was sandpaper, no acid etching for me at all.
Pascal
flying-nut(at)cfl.rr.com Guest
Posted: Fri Oct 14, 2016 8:45 am Post subject: Another windscreen Q |
IMHO and it's only my opinion ..... if the aluminum is clean and without
corrosion the epoxy resin will stick just fine.
However, in your situation, I would lay some 3M fineline tape where the
windshield meets the fuse and wipe the phosphoric acid on the aluminum
using a paper towel .... or either a lightly loaded foam brush so there
isn't a chance of getting the acid under the windshield where you can't
get it out. I've always neutralized the acid with baking soda/water and
drying with a towel.
Linn
On 10/14/2016 12:29 PM, Phillip Perry wrote:
Phil
Posted: Fri Oct 14, 2016 8:56 am Post subject: Another windscreen Q |
I was thinking composite not aluminum- no sandpaper on aluminum at all.
Correction:
I used a scotchbrite pad and vinegar to acid etch all my aluminum, than power washed area with water. In your case spray vinegar on area and scotchbrite than wipe down with wet towel, rinse and redo wipe down until it is dull and clean. Shouldn't be an issue for the hardware if done in sections.
Pascal
Posted: Fri Oct 14, 2016 8:57 am Post subject: Another windscreen Q |
We never acid etch it.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
| Quote: | On Oct 14, 2016, at 12:29 PM, Phillip Perry <philperry9(at)gmail.com> wrote:
Phil
johngoodman
Posted: Sat Oct 15, 2016 4:47 am Post subject: Re: Another windscreen Q |
I used an aluminum windshield fairing, instead of fiberglass. I really like it, and it turned out great. Can't remember the name of the company I bought it from.
John
_________________ #40572 Phase One complete in 2011 |
