O-200 Engine Tightness
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
vk3eka(at)bigpond.net.au
PostPosted: Fri Oct 14, 2016 1:44 pm    Post subject: O-200 Engine Tightness Reply with quote
Hi Guys,
I have noticed that directly after flying my O-200 powered Zodiac 601XLB that when turning the prop over, it seems to be tight.
I recently finished an annual and found some metal filings in the oil filter. I stripped the engine and replaced the crankshaft gear cluster and added a new starter gear.
During the stripping of the engine I noticed the bearings were slightly discoloured. The engine has 180 hours since a major rebuild.
I had the engine parts inspected by the local engine shop and he found I hadn't used the two special bolts to hold the crankcase halves in alignment.
He checked all the clearances (all good) and reassembled the engine halves and the cylinders for me including the two special bolts.
I re-installed the engine and all is working well but I still find the engine stiff to turn over after flight.
The oil temp stays around 180 F and power is good. It doesn't seem to make any difference whether I fly for an hour or for 20 minutes.
After the engine has cooled the tightness disappears.
Is there anything I should be looking at?
Peter
Wonthaggi Australia
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
jack(at)bedfordlandings.c
PostPosted: Sat Oct 15, 2016 5:03 am    Post subject: O-200 Engine Tightness Reply with quote
Peter, the A65 on my Pietenpol is the same.  It is much looser when cold, and after flying for a short while is noticeably tighter.  Mine has about 375 hours SMOH.  I think that is just a characteristic of the small Continentals.
Jack Phillips
Smith Mountain Lake, Virginia
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Peter Johnson
Sent: Friday, October 14, 2016 5:41 PM
To: continental-list(at)matronics.com
Subject: O-200 Engine Tightness
Hi Guys,
Peter
Wonthaggi Australia
PostPosted: Sat Oct 15, 2016 3:26 pm    Post subject: O-200 Engine Tightness Reply with quote
Jack,
Thanks for that. A little piece of mind.
I haven’t noticed the same on my A65 powered Piet but that may have more hours on it and loosened up a bit more.
Cheers
Peter
Wonthaggi Australia
From: <owner-continental-list-server(at)matronics.com> on behalf of Jack Philips <jack(at)bedfordlandings.com>
Reply-To: <continental-list(at)matronics.com>
Date: Sunday, 16 October 2016 at 12:02 am
Subject: RE: O-200 Engine Tightness
Jack Phillips
Hi Guys,
Peter
Wonthaggi Australia
stephencliverichards(at)g
PostPosted: Tue Oct 18, 2016 9:46 am    Post subject: O-200 Engine Tightness Reply with quote
Our 0200 is the same 80 hours after replacing barrels and pistons
Sent: ‎16/‎10/‎2016 00:28
To: continental-list(at)matronics.com (continental-list(at)matronics.com)
Subject: Re: O-200 Engine Tightness
Jack,
Cheers
Peter
Wonthaggi Australia
Jack Phillips
Hi Guys,
Peter
Wonthaggi Australia
PostPosted: Tue Oct 18, 2016 1:04 pm    Post subject: O-200 Engine Tightness Reply with quote
Thanks Steve
Peter
On 19 Oct. 2016, at 4:46 am, Stephen Richards <stephencliverichards(at)gmail.com (stephencliverichards(at)gmail.com)> wrote:
Subject: Re: Continental-List: O-200 Engine Tightness
Jack,
Cheers
Peter
Wonthaggi Australia
From: <owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)> on behalf of Jack Philips <jack(at)bedfordlandings.com (jack(at)bedfordlandings.com)>
Reply-To: <continental-list(at)matronics.com (continental-list(at)matronics.com)>
Subject: RE: Continental-List: O-200 Engine Tightness
Jack Phillips
From: owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com) [mailto:owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)] On Behalf Of Peter Johnson
Hi Guys,
Peter
Wonthaggi Australia
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
