Strobe bulb, max rpm, cig lighter switch
Dee One
PostPosted: Sun Oct 30, 2016 1:57 pm    Post subject: Strobe bulb, max rpm, cig lighter switch Reply with quote
Update on rough running engine. After two mechanics diagnosing the engine on several occasions, finally got the engine running correctly. The problem was in the carburetors. Even though we had both carburetors rebuild in February, they apparently were not correctly cleaned. Debris or build up in the very small orifices and/or jets was causing the problem. Had the carburetors rebuilt again, this time with thorough cleaning, and now the engine runs great. Took seven months to solve this issue; but learn from it. Dee LeBlanc
leblancds(at)cox.net (leblancds(at)cox.net)
cell 225-802-1038
The Past is History
The Future is a Mystery
Today is a Gift
That’s Why They Call it the Present
On Aug 31, 2016, at 3:22 PM, N456TS <bottleworksnet(at)gmail.com (bottleworksnet(at)gmail.com)> wrote:
--> Allegro-List message posted by: "N456TS" <bottleworksnet(at)gmail.com (bottleworksnet(at)gmail.com)>WOT at 5k is too low. It could be over pitched or the engine is producing low power. You posted before about your engine running rough. Did you solve that (and what was the issue)? What CHT and EGT temps are you getting under this condition?--------N456TSRead this topic online here:http://forums.matronics.com/viewtopic.php?p=460075#460075
The Past is History
Today is a Gift
