				 Posted: Wed Nov 30, 2016 10:43 am    Post subject: Installing the "Red cube" |
				Guys
 Those of you who installed the fuel flow sensor (aka the "red cube") below the engine, between the throttle body and the fuel distribution "spider", you had to order a small fire sleeved fuel line, right?
 Can you please tell me where did you order it, and the specifications (length, diameter and type & size of the fittings) of that extra fuel line?
 Carlos
		Lenny Iszak
				 Posted: Wed Nov 30, 2016 11:30 am    Post subject: Re: Installing the |
				You'll need two lines, one from the servo to redcube and the other from the redcube to the spider. The dimensions depend on how and where you are mounting the redcube. Some fuel line makers can chop your original fuel line in two and put two new ends on them. If you already have your fuel line that might be a good option.
 I got integral firesleeved hoses from Stratoflex, but I think the ceramic fibers in the red firesleeve keeps the hose a bit cooler than the brown integral silicone.
 Lenny
		flying-nut(at)cfl.rr.com Guest
				 Posted: Wed Nov 30, 2016 11:31 am    Post subject: Installing the "Red cube" |
				I have lots of JIC fittings for the braided steel/teflon hose.  So, I
 cut the kit hose from the mechanical fuel pump to the fuel servo.  Bad
 move.  The teflon liner wasn't the correct size for my fittings so I
 made up two hoses and used the firesleeve from the kit hose.  I mounted
 my FF sender on a plate attached to the lower, fwd engine mount tube
 with Adel clamps.  I wanted as much straight in/out as I could get.
 Different from the vertical hose you want, but the idea is the same.
 You can get the braided/teflon hose with 37* fittings at most any
 hydraulic shop ..... tell them it's for a race car or airboat .... they
 don't like to hear 'airplane'.
 Linn
 On 11/30/2016 1:39 PM, Carlos Trigo wrote:
  Guys
  Carlos
		TimRVator(at)comcast.net Guest
				 Posted: Thu Dec 01, 2016 7:54 pm    Post subject: Installing the "Red cube" |
				I made my own two hoses (servo to cube, cube to spider):
 4 ea Eaton Hose Fitting F66000-4 (ACS part 05-01320)
 Aeroquip clamps for hose ends, and to clamp firesleeve to red cube -
 Aeroquip Clamp 900591B-2C, -1C, and -3C.
 Aeroquip Firesleeve AE102-8 (5 feet)
 Aeroquip Firesleeve AE102-24 (1 foot)
 Aeroquip Hose #666-4 (6 feet).
 Aeroquip publishes instructions on how to assemble.
 Tim Lewis -- HEF (Manassas, VA)
 A&P
 RV-6A N47TD -- 1104 hrs - sold
 RV-10 N31TD -- 740 hrs
 Carlos Trigo wrote on 11/30/2016 10:39 AM:
  Guys
  Carlos
				 Posted: Fri Dec 02, 2016 3:22 am    Post subject: Installing the "Red cube" |
				Thanks a lot Tim
 That's exactly the information I needed!
 Cheers
 Carlos
 -----Mensagem original-----
 De: owner-rv10-list-server(at)matronics.com
 [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Tim Lewis
 Enviada: Friday, December 2, 2016 3:54 AM
 Para: rv10-list(at)matronics.com
 Assunto: Re: Installing the "Red cube"
 4 ea Eaton Hose Fitting F66000-4 (ACS part 05-01320) Aeroquip clamps for
 hose ends, and to clamp firesleeve to red cube - Aeroquip Clamp 900591B-2C,
 -1C, and -3C.
 A&P
  Guys
