FAB box
cjhukill(at)cox.net
PostPosted: Tue Dec 06, 2016 7:38 am    Post subject: FAB box Reply with quote
or you can do this
 Filesize:  1.94 MB
 Viewed:  2319 Time(s)
 Filesize:  1.84 MB
Kelly McMullen
PostPosted: Tue Dec 06, 2016 4:45 pm    Post subject: FAB box Reply with quote
Chris,
That looks like a very good solution. I don't quite understand how the rear inlets are constructed, but certainly solves all issues with blockage in the front 2/3 of inlet. If you have any other pictures of fabricating this mod, I would be very interested.
-sent from the I-droid implanted in my forearm
On Tue, Dec 6, 2016 at 8:36 AM, Chris Hukill <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
or you can do this
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
flying-nut(at)cfl.rr.com
PostPosted: Tue Dec 06, 2016 5:37 pm    Post subject: FAB box Reply with quote
Here's what I did.  I didn't want any control that I could not reset in flight so ......
[img]cid:part1.A2A74A2A.DDC2EDC1(at)cfl.rr.com[/img]
Made a blue foam plug on the FAB and glassed over it. Filed the plate to an oval shape that seals pretty good at an angle in the tube.
Linn
On 12/6/2016 7:45 PM, Kelly McMullen wrote:
Chris,
or you can do this
 Filesize:  97.55 KB
 Viewed:  2308 Time(s)
