FYI December 2014 issue IFR flying
dlm34077
PostPosted: Mon Jan 02, 2017 6:18 am    Post subject: FYI December 2014 issue IFR flying Reply with quote
Because it is winter, there is a good article on Ice and tail stalls in the referenced issue. I don’t fly ice anymore but should you encounter it flying the 10, the article provides some does and don’ts. Having flown a Cessna Cardinal for about 30 years and built a Glastar in addition to a 10, I have learned a little about tail stalls. I first heard of the problem and considered it back when the C177 did not have the slots in the tail. Pilots were trying to land the Cardinal and in the flare with flaps deployed, they stalled the horizontal stabilator. The result was a rapid pitch downward and a damaged nose gear. This problem can also be demonstrated in the Glastar. It can be built improperly with the wrong horizontal stabilizer angle of incidence and a tail stall can be experienced in the flare even without flaps deployed. Mine was built properly but the pilot who made first flight in my Glastar made the approach at 10-20 knots faster than normally required and no flaps to protect himself from such a potential problem. The referenced article also notes that tail stalls can also be experienced with flaps deployed and ice on the tail. The problem exists both for high and low wing aircraft. My plans are to stay out of ice but should I encounter and experience a tail stall I plan to be prepared.
David McNeill
COM, CFII, A&P
N46007
N48007
And a few numbers reserved
www.avast.com
Lew Gallagher
PostPosted: Mon Jan 02, 2017 6:52 am    Post subject: FYI December 2014 issue IFR flying Reply with quote
http://www.ifr-magazine.com/issues/1_39/features/Ice-and-Tail-Stalls_478-1.html
Later, – Lew
Sent: Monday, January 02, 2017 9:17 AM
Subject: FYI December 2014 issue IFR flying
David McNeill
COM, CFII, A&P
N46007
N48007
www.avast.com
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
Mauledriver(at)nc.rr.com
PostPosted: Tue Jan 03, 2017 11:04 am    Post subject: FYI December 2014 issue IFR flying Reply with quote
Thanks!  Good article there.
FWIW, I've learned to first look for ice on my 10's stabilizer.  It's easiest to see there but I think that's because it is red rather than white like the wing.  Conversely, I've found it very difficult to see ice on the wing.  I once had a very slow degradation in airspeed due to ice was never able to see the ice on the wing.
I've considered painting some kind of dark patch on the wing near the left root so I might be able to detect ice ASAP and get the hell out of there.  Has anyone done that?  Any ice detection pireps for the '10?
www.avast.com
www.avast.com
EdKranz
PostPosted: Wed Jan 04, 2017 8:24 am    Post subject: FYI December 2014 issue IFR flying Reply with quote
Ice detection is one of the big reasons that the leading edges of my wings and stab are black (that and the design looked good!) I've picked up trace in hazy VMC, and the black paint made the ice stand out pretty clearly.
....plus bugs don't show up as much Smile
On Tue, Jan 3, 2017 at 1:03 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
www.avast.com
www.avast.com
Ed Kranz
RV10
Finishing
www.edandcolleen.com
