Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Thu Jan 12, 2006 2:25 pm Post subject: Solder Station |
Does anyone on the list know about SOLDER STATIONS? I only know they exist
but need to decide what to buy for medium use in a GA repair hangar. It
will be used for very light to heavy AWG wire size. Any name brands, models
or sizes to choose from out there?
Thanks ...
Jerry Grimmonpre'
Dan.Beadle(at)hq.inclines Guest
Posted: Thu Jan 12, 2006 2:52 pm Post subject: Solder Station |
Most solder stations are designed for small wire - #22 and smaller, but
you can make-do for larger wires. Weller is the oldest, probably best.
For heavy wire you probably want a higher wattage, with more thermal
mass. These are usually un-regulated. These are usually under $50.
Try www.digikey.com and search for solder. Good solder station is $250
or so.
Radio Shack has a pretty good one for $79 - pre-set temps, etc. But I
have had two of them fail on me.
Dan
aadamson(at)highrf.com Guest
Posted: Thu Jan 12, 2006 3:13 pm Post subject: Solder Station |
If ya want the best, and the fastest, use a Metcal... They use RF to heat
the tip, they are instant on, and are my favorite to use. They are a little
pricy, but watch ebay for deals
Alan
mprather(at)spro.net Guest
Posted: Thu Jan 12, 2006 3:57 pm Post subject: Solder Station |
I like to have access to at least 2 ways to melt solder. The first is
with a fine, high quality pencil iron which will be used on small wire
being attached to small pins which may reside in close quarters. Fine
point, adjustable temperature are the key features. And then a big gun
for use on heavy wire. It may raise the hackles of the purests, but I'd
consider not having the heavy gun in lew of a butane/propane torch which
would handle the heaviest of wires.
In soldering (at least), sophistication of technique can often make up for
lack of sophistication of equipment.
Matt-
<jerry(at)mc.net>
exist but need to decide what to buy for medium use in a GA repair
hangar. It will be used for very light to heavy AWG wire size. Any
name brands, models or sizes to choose from out there?
Thanks ...
Jerry Grimmonpre'
Posted: Thu Jan 12, 2006 4:20 pm Post subject: Solder Station |
see below....
or so.
Dan
bnn(at)nethere.com Guest
Posted: Thu Jan 12, 2006 4:47 pm Post subject: Solder Station |
At 02:24 PM 1/12/2006, you wrote:
| Quote: | Does anyone on the list know about SOLDER STATIONS?
| Quote: | Any name brands, models
The Metcal SP200 is a wonderful unit. It has replaceable tips so you can
solder small and large, though I don't know how large. It heats fast and
has a steady tip temp. See there web site for specifics. Best of all these
appear quite regularly on Ebay. Not sure why. Be patient and you can pick
them up at a serious discount.
Guy Buchanan
K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar.
Eric M. Jones
Posted: Thu Jan 12, 2006 4:53 pm Post subject: Re: Solder Station |
Try eBay "solder station". Weller is good but there are other name brands, "American Beauty", and others. When you buy offbrand you run the risk of not being able to get tips and parts easily. I have an ER-brand SD203 which is going to succumb to that fate soon.
For the big wattage requirements, either a gun type available anywhere or for production work, the baton-type "Big-Old-Iron" available at any flea market, or in the bottom of your oldest tool box.
My most valuable suggestion is to AVOID the wet sponge mess and use a stainless steel chore-boy stuffed into a heavy pipe to clean your tip. I wish I'd know about this years earlier.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
jschroeder(at)perigee.net Guest
Posted: Thu Jan 12, 2006 5:56 pm Post subject: Solder Station |
The ones on EBay are most likely from an enterprising set of folks who buy
them from the big electronics mfg's or repair stations and auction/sell
them on eBay.
Do not archive.
John
On Thu, 12 Jan 2006 16:45:25 -0800, Guy Buchanan <bnn(at)nethere.com> wrote:
| Quote: | Best of all these
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Thu Jan 12, 2006 8:19 pm Post subject: Solder Station |
In a message dated 01/12/2006 7:43:26 PM Central Standard Time,
emjones(at)charter.net writes:
PLEASE elaborate, Eric! Never heard of a "chore-boy" down here in the 3rd
wirld...
Mark do not archive
_________________ From The PossumWorks... |
Posted: Fri Jan 13, 2006 2:18 am Post subject: Solder Station |
Heck, I live in the US and I've never heard it called that. But I am
guessing he is talking about an abrasive pad made of stainless steel
turnings.
-- Craig
harley(at)AgelessWings.co Guest
Posted: Fri Jan 13, 2006 4:39 am Post subject: Solder Station |
Morning, Guys...
Chore Boy is a brand name. They make scouring pads of copper or
stainless steel mesh. I've heard that it is also used in making crack
cocaine!
Here's what the box looks like (you can get them at many grocery and
drug stores.):
www.instawares.com/Chore-Boy-Stainless-Steel-Scouring-Pads.41496RC.0.7.htm
or:
http://tinyurl.com/7or7z
Harley Dixon
turnings.
-- Craig
BobsV35B(at)aol.com Guest
Posted: Fri Jan 13, 2006 5:56 am Post subject: Solder Station |
In a message dated 1/13/2006 4:20:01 A.M. Central Standard Time,
craig(at)craigandjean.com writes:
turnings.
-- Craig
'Chore Boy' is brand name.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
Posted: Fri Jan 13, 2006 6:29 am Post subject: Solder Station |
Mark -
It is an old time pot scrubber made from curls of metal - (kinda like
shavings from drill or milling machines). Problem now is where to get
them. Eric?? Know any sources?
John Schroeder
Lancair ES - Painting
On Thu, 12 Jan 2006 23:18:06 EST, <Fiveonepw(at)aol.com> wrote:
| Quote: | PLEASE elaborate, Eric! Never heard of a "chore-boy" down here in the
3rd
wirld...
Eric M. Jones
Posted: Fri Jan 13, 2006 6:32 am Post subject: Re: Solder Station |
Guys,
Anyone who has ever scrubbed a pot in the kitchen or made a crack pipe out of a glass tube knows what a Chore Boy is. Grocery stores now have to keep them under the counter because of use #2....
These are a universally-popular brand of knitted stainless or brass metal pot scrubbers. Google "Chore Boy" = 800,000 pages. Cheeeeze...
In technical circles thay are useful in the lab as prefilters and mufflers and a zillion other uses. Oh yes...and they make great soldering-tip cleaners, too.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
bakerocb(at)cox.net Guest
Posted: Fri Jan 13, 2006 9:36 am Post subject: Solder Station |
Responding to an AeroElectric-List message previously posted by: "Eric M.
Jones" <emjones(at)charter.net>
<<......skip......My most valuable suggestion is to AVOID the wet sponge
about this years earlier. Eric M. Jones>>
1/13/2006
Hello Eric, A couple of centuries ago as a young lad on the farm I had to
solder leaks in the milk pails. The preferred method of cleaning the
soldering iron tip back then was to rub the heated tip on a small block of
sal ammoniac.
Has that method fallen by the wayside? Thanks.
OC
N1deltawhiskey(at)comcast Guest
Posted: Fri Jan 13, 2006 11:06 am Post subject: Solder Station |
OC,
Never heard of sal ammoniac! Googled it and came up with some interesting
information, including a site that recommends it for cleanding soldering
tips: www.glassmart.com. Click on soldering Irons, block is at the bottom.
Doug Windhorn
Mark Phillips in TN
Eric M. Jones
Posted: Fri Jan 13, 2006 2:10 pm Post subject: Re: Solder Station |
Re: Sal Ammoniac--
Yes it's around. I keep a roll of yellow "Caution: Hazardous Chemical Spill" warning tape around for when we need to use it. When a hot iron hits Sal Ammoniac, it turns in to ammonia gas and hydrochloric acid vapor. Does a great job of cleaning. And when the workers get sick, we just call INS and have them set back across the border.
Re: Chore Boys. These are available everywhere from your local grocer to the hardware store. Yes "Chore Boy" is a trade name for....ah.....whatever they're called.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
Jerry Grimmonpre'
Posted: Fri Jan 13, 2006 2:48 pm Post subject: Solder Station |
Many thanks to the aeroelectric-list ... and appreciation for the
contributors to the "Solder Station" thread.
To sum up ... it went like this: "all we want to do is melt solder neatly,
cost effectively and efficiently". With this in mind the KISS method
pointed to ... "get the soldering skills up high and the cost low". That
led to Radio Shack because they have low cost supplies. Their Mini Butane
Gas Powered Iron is my choice for the heavy stuff. It's Model: 64-2188 ....
20 bucks. For the small to medium size wires there are several watt sizes.
Those from 40w down to 15w ... under 10 bucks.
For 30 bucks you're in the soldering business, now just practice ... oh! and
don't forget the stainless steel scrubbers
This list is the greatest thing since sliced bread, thanks.
Regards ...
Jerry Grimmonpre'
nuckollsr(at)cox.net Guest
Posted: Fri Jan 13, 2006 3:52 pm Post subject: Solder Station |
years earlier.
We use the sponges here but they MUST be cellulose.
Real sponge and plastics are not suited to the task.
Cleaning section of any grocery store has a 3-pak
of cellulose sponges for $1 or so.
