dan(at)syz.com Guest
Posted: Wed Feb 22, 2017 4:57 pm Post subject: Jacking the RV-10 |
I'm building the wheel fairings and am at the part in the plans where I jack up the plane for alignment so the wheels are oriented as they are in flight (though they don't give specific recommendations on how to do this). I've built wing jacks, along with a socket that screws into the wing tiedown bolt holes that a well-supported bottle jack can fit into. I'm not too worried about the jack slipping out of place, and so far as I know, other RV-10 builders have jacked up their planes in this manner. But I just wanted to check before I do it that I'm not doing something stupid - the tiedown bolt hole locations are strong enough for this, aren't they? Obviously, the wings are strong enough to support the weight of the plane, but I just wanted to double check first, considering that when jacking the wings, all the force is in the one location of the tiedown bolt hole, instead of distributed more evenly along the wing as it is in flight.
Any gotchas to be aware of before I do this, other than the obvious making sure the nose wheel is well chocked first, and raising both wings simultaneously to keep things relatively level?
Also, the plans call for lateral and longitudinal levelling when fitting the fairings. When the plane sits on the ground, the level datum (door sill) is tipped a few degrees nose high - but they say to only jack up the plane until the main wheels are no more than 1/16" off the floor. I haven't done it yet, but in doing so, will that straighten out the lateral (pitch) axis sufficiently level as the weight is taken off the main gear legs? I can raise the nose wheel for lateral levelling if it's too nose low with the mains 1/16" off the floor, but if it's still nose high, the only way I could see to laterally level it would be to dig a hole for the nose gear
Thanks!
Dan
Dan Charrois
President, Syzygy Research & Technology
Phone: 780-961-2213
Bob Turner
Joined: 03 Jan 2009 Posts: 883 Location: Castro Valley, CA
Posted: Wed Feb 22, 2017 5:17 pm Post subject: Re: Jacking the RV-10 |
Fine-tune the fore-aft leveling by adding/letting out air from the nose tire.
_________________ Bob Turner
RV-10 QB |
flying-nut(at)cfl.rr.com Guest
Posted: Wed Feb 22, 2017 5:22 pm Post subject: Jacking the RV-10 |
Nothing to worry about using the socket/bolt as a jack point. recently
did that on an RV-9. I would put a large area washer between the wing
and the socket to prevent a smiley from the socket .... since it's at an
angle to the jack. When I did my wheel pants I jacked up the mains and
used a scissor jack under the nosegear nut to level the door sill. The
1/16" isn't critical .... you just need to get the mains and the nose
wheel off the ground to simulate level flight.
Linn
Thanks!
Dan
Dan Charrois
Phone: 780-961-2213
Checked by AVG - www.avg.com
Posted: Wed Feb 22, 2017 5:43 pm Post subject: Jacking the RV-10 |
I jacked up the mains using jacks just inside the gear and used a
scissors jack under the nose gear to find out where level was. Used
cinder blocks and small bottle jack under the firewall (2x4 across the
fuse) to level with all three wheels off the floor and did all three
pants before putting back on the floor.
Linn
Kelly McMullen
Posted: Wed Feb 22, 2017 6:12 pm Post subject: Jacking the RV-10 |
See if you can't borrow a set of real aircraft jacks. You will need the plane in the air for a day or two, and you don't want to be relying on a jerry rigged jack. Carriage bolts with the round head work fine for jack points. I used the same jacks that I use to do retraction checks on my Mooney. I think you will be surprised how many aircraft owners have a set of jacks.
-sent from the I-droid implanted in my forearm
On Wed, Feb 22, 2017 at 5:52 PM, Dan Charrois <dan(at)syz.com (dan(at)syz.com)> wrote:
Quote: | --> RV10-List message posted by: Dan Charrois <dan(at)syz.com (dan(at)syz.com)>
Thanks!
Dan
Dan Charrois
Phone: [url=tel:780-961-2213]780-961-2213[/url]
FORUMS -
WIKI -
b Site -
     -Matt Dralle, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Leeverett
Posted: Wed Feb 22, 2017 6:13 pm Post subject: Jacking the RV-10 |
Is that a yearly fee? From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Linn Walters <flying-nut(at)cfl.rr.com>
Sent: Wednesday, February 22, 2017 7:39:46 PM
Subject: Re: Re: Jacking the RV-10
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com>
Linn
> --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu>
> Bob Turner
> RV-10 QB
> http://forums.matronics.com/viewtopic.php?p=466523#466523
> No virus found in this message.
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; -Matt Dralle, List Admin.
Van's recommended point for jacking up the plane is the tie downs. The lift in flight is over a bigger surface, but the forces are transferred through the spar to the fuselage.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
Thanks!
Dan
Dan Charrois
Phone: 780-961-2213
