Separating IO-540 Standard flange Crankcase
n5qg(at)verizon.net
PostPosted: Wed Jan 18, 2017 4:11 pm    Post subject: Separating IO-540 Standard flange Crankcase Reply with quote
I have IO-540-C4B5 engine that needs to be split and rebuilt for my RV-10 build project. I plan on machining new ST-122 pressure plates and 8 bolts/nuts to separate the engine case since Lycoming does not provide this tool anymore.
Does anybody have the dimensions of the Lycoming pressure plates ST-122 and the size of the bolts/nuts used to separate Lycoming crankcases. I understand the ST-122-2 bolts thread onto the crankcase Thru-Studs, plates installed both sides of the case with nuts & washers added to the ST-122-2 bolts to secure the plates. When the nuts are tightened down it causes the pressure plates push against the other Thru-Studs that are up against the inside of the pressure plates, causing the case halves to separate. Specifically, what is O/D of the ST-122-2 bolts, the inside depth the bolts are threaded to accept the Thru-Studs? Also, what size thread is on the outside of the bolts and nuts?
Any information regarding the ST-122 tool will be gratefully appreciated.
Mark
Ft. Worth, Tx
TimRVator(at)comcast.net
PostPosted: Sat Jan 21, 2017 3:36 pm    Post subject: Separating IO-540 Standard flange Crankcase Reply with quote
http://nickugolini.com/Website/CaseSplitter/case_splitter.htm
Tim Lewis -- HEF (Manassas, VA)
A&P
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 740 hrs
mark wrote on 1/18/2017 7:10 PM:
the bolts and nuts?
Mark
Ft. Worth, Tx
