Separating IO-540 Standard flange Crankcase
flyinwithme99(at)yahoo.co
PostPosted: Wed Jan 18, 2017 4:31 pm    Post subject: Separating IO-540 Standard flange Crankcase Reply with quote
There is a better way. I will send pics if the tools i used for years by the morning
Sent from Yahoo Mail on Android
On Wed, Jan 18, 2017 at 6:10 PM, mark
<n5qg(at)verizon.net> wrote:
I have IO-540-C4B5 engine that needs to be split and rebuilt for my RV-10 build project. I plan on machining new ST-122 pressure plates and 8 bolts/nuts to separate the engine case since Lycoming does not provide this tool anymore.
Does anybody have the dimensions of the Lycoming pressure plates ST-122 and the size of the bolts/nuts used to separate Lycoming crankcases. I understand the ST-122-2 bolts thread onto the crankcase Thru-Studs, plates installed both sides of the case with nuts & washers added to the ST-122-2 bolts to secure the plates. When the nuts are tightened down it causes the pressure plates push against the other Thru-Studs that are up against the inside of the pressure plates, causing the case halves to separate. Specifically, what is O/D of the ST-122-2 bolts, the inside depth the bolts are threaded to accept the Thru-Studs? Also, what size thread is on the outside of the bolts and nuts?
Any information regarding the ST-122 tool will be gratefully appreciated.
Mark
Ft. Worth, Tx
ejharris813wk(at)comcast.
PostPosted: Wed Jan 18, 2017 7:11 pm    Post subject: Separating IO-540 Standard flange Crankcase Reply with quote
Mark
Google st122tool and rent it for 125$
Sent from my Verizon Wireless 4G LTE smartphone
-------- Original message --------
Date: 01/18/2017 7:10 PM (GMT-05:00)
To: lycomingengines-list(at)matronics.com
Subject: LycomingEngines-List: Separating IO-540 Standard flange Crankcase
<![endif]--> <![endif]-->
I have IO-540-C4B5 engine that needs to be split and rebuilt for my RV-10 build project.� I plan on machining new ST-122 pressure plates and 8 bolts/nuts to separate the engine case since Lycoming does not provide this tool anymore.
Does anybody have the dimensions of the Lycoming pressure plates ST-122 and the size of the bolts/nuts used to separate Lycoming crankcases.� I understand the ST-122-2 bolts thread onto the crankcase Thru-Studs, plates installed both sides of the case with nuts & washers added to the ST-122-2 bolts to secure the plates.� When the nuts are tightened down it causes the pressure plates push against the other Thru-Studs that are up against the inside of the pressure plates, causing the case halves to separate.� Specifically, what is O/D of the ST-122-2 bolts, the inside depth the bolts are threaded to accept the Thru-Studs?� Also, what size thread is on the outside of the bolts and nuts?
Mark
Ft. Worth, Tx�
