pastormac62
Posted: Tue Jan 10, 2017 8:59 am Post subject: Lens for landing light? |
Hi Guys,
I want to add a landing light to my TR-1. Do you know where I can purchase an acrylic cover that would match the leading edge of the wing? Or have any thoughts? I know Van's sells a kit, but didn't know if it matched our leading edge.
Thanks!
Steve
| Quote: | On Jan 3, 2017, at 4:09 AM, Keith.Miller(at)esa.int wrote:
Steve
OC is right. Its best to have a bit of baggage in the back when solo.
I can see from my own calculations that with just me on board ( 150Lbs ) if
I run it completely out of fuel , I could be getting close to the most
forward Cof G, without anything in the back . - luckily for me i always have
a load of junk ( aircraft tie down kit , spare headset, aircraft log books ,
airfield manuals....) in the back.
Keith
To: kis-list(at)matronics.com
Date: 12/21/2016 01:56 AM
Subject: Re: Gross Weight of TR-1?
Sent by: owner-kis-list-server(at)matronics.com
Hi Keith,
Thanks for the reply! My battery is located behind the passenger seat and
still was told to fly with 30 lbs in the area when flying solo.
Steve
> On Dec 20, 2016, at 7:28 AM, Keith.Miller(at)esa.int wrote:
> Steve
> flying solo with 30Lbs in the back when solo , doesn't make a lot of sense
> on a TR-1 , it should be possible by repositioning the battery to get a
> much better C oF G all round , my battery is located directly behind the
> copilots seat which results in a empty Cof G at STA 58.75 ( Cof G must
be
> in range STA 61.5 to STA 65.6) . With the empty Cof G at 58.75 its almost
> impossible to exceed the forward C of G solo. ( Pilot weight is located
at
> STA 80 in my TR-1 as measured and calculated from the weighing scales ).
> depending on your empty Cof G i would seriously consider moving the
battery
> further back
> (With an Io240 B engine max take off is 1450lbs).
> Keith
> From: pastormac(at)comcast.net
> Date: 12/18/2016 04:44 PM
> Thank you! After repainting the plane and a new weight an balance, when I
> fly solo I'm having to place 30 lbs behind the seat in baggage area to have
> the proper weight distribution. I have 15 gal tanks in each wing and can
> only fly with 10 gal in each. Is this common? I weigh 195. My wife flys
with
> me we can have 10 in each tank and 25 baggage she weighs 135. Just the way
> the numbers came out.
> Sent from my iPhone
> On Dec 17, 2016, at 9:19 PM, Galin Hernandez <galinhdz(at)gmail.com> wrote:
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
bakerocb
Posted: Tue Jan 10, 2017 12:17 pm Post subject: Lens for landing light? |
1/10/2017
Hello Steve, This can be a real do-it-yourself project. Make a simple mold,
buy acrylic sheet from a craft or hardware store (it is really very
inexpensive), heat the acrylic in an oven, drape over mold, trim to fit,
drill holes for fastening screws, and install.
Don't over think this, it is really very easy and simple. Plan on ruining
the first two or three that you make. If you are willing to tackle this, ask
me for more details. Check the internet for molding acrylic sheet.
OC
PS: What kind of lights are you planning to put under the lens?
Sent: Tuesday, January 10, 2017 11:58 AM
Subject: Lens for landing light?
Hi Guys,
leading edge.
Thanks!
Steve
galinhdz(at)gmail.com Guest
Posted: Tue Jan 10, 2017 3:35 pm Post subject: Lens for landing light? |
Steve; FWIW I made my own out of a piece of Plexiglas bought at Home Depot. Cut it slightly larger than needed then using a heat gun CAREFULLY warm it up until you can just barely mold it with a long piece of wood. Do it very slow and it will come out just fine. I practiced with a few pieces until I got the technique down pat.
On Tue, Jan 10, 2017 at 11:58 AM, <pastormac(at)comcast.net (pastormac(at)comcast.net)> wrote:
| Quote: | --> KIS-List message posted by: pastormac(at)comcast.net (pastormac(at)comcast.net)
Hi Guys,
Thanks!
Steve
> On Jan 3, 2017, at 4:09 AM, Keith.Miller(at)esa.int (Keith.Miller(at)esa.int) wrote:
> --> KIS-List message posted by: Keith.Miller(at)esa.int (Keith.Miller(at)esa.int)
> Steve
> airfield manuals....)Â Â in the back.
> Keith
> From:Â Â pastormac(at)comcast.net (pastormac(at)comcast.net)
> To:Â Â kis-list(at)matronics.com (kis-list(at)matronics.com)
> Date:Â Â 12/21/2016 01:56 AM
> Subject:Â Â Re: Gross Weight of TR-1?
> Sent by:Â Â owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)
> Hi Keith,
> Steve
> Sent from my iPhone
>> On Dec 20, 2016, at 7:28 AM, Keith.Miller(at)esa.int (Keith.Miller(at)esa.int) wrote:
>> Steve
> be
> at
> battery
>> further back
>> Keith
>> Date:Â Â 12/18/2016 04:44 PM
> with
>> Sent from my iPhone
>> On Dec 17, 2016, at 9:19 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?KIS-List
FORUMS -
_blank" rel="noreferrer">http://forums.matronics.com
WIKI -
lank" rel="noreferrer">http://wiki.matronics.com
b Site -
     -Matt Dralle, List Admin.
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
pastormac62
Posted: Tue Jan 10, 2017 4:22 pm Post subject: Lens for landing light? |
Thanks Galin. How did you get the form for your wing?
On Jan 10, 2017, at 6:35 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
| Quote: | Steve; FWIW I made my own out of a piece of Plexiglas bought at Home Depot. Cut it slightly larger than needed then using a heat gun CAREFULLY warm it up until you can just barely mold it with a long piece of wood. Do it very slow and it will come out just fine. I practiced with a few pieces until I got the technique down pat.
Hi Guys,
Thanks!
Steve
> Steve
> Keith
> From: pastormac(at)comcast.net (pastormac(at)comcast.net)
> To: kis-list(at)matronics.com (kis-list(at)matronics.com)
> Sent by: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)
> Hi Keith,
> Steve
> Sent from my iPhone
>> Steve
> be
> at
> battery
>> further back
>> Keith
> with
>> Sent from my iPhone
FORUMS -
WIKI -
b Site -
Posted: Wed Jan 11, 2017 5:56 am Post subject: Lens for landing light? |
My airplane was already built so the shape was already there.
I cut the plexiglas to the correct width but slightly longer than needed. I drilled the top holes then screwed the plexiglas in place. As I applied heat I pressed down on the plexiglas with the long piece of wood until it couldn't go any lower. Don't over heat it or the Plexiglas will sag. I did one small area at a time until it was completely formed around the wing. Once the lens was complete, I cut the excess length off and drilled the bottom holes.
Believe me, it is easier said than done. I took me three tries to get the technique down pat but plexiglas is cheap. Be ready to mess up the first few tries but you will really like how it comes out.
Here is a short video of the lights. The lens is so clear it looks as though it isn't even on.
https://www.youtube.com/watch?v=s2Den_xrmvgÂ
Â
On Tue, Jan 10, 2017 at 7:22 PM, <pastormac(at)comcast.net (pastormac(at)comcast.net)> wrote:
| Quote: | Thanks Galin. How did you get the form for your wing? Â
Hi Guys,
Thanks!
Steve
> Steve
> Keith
> Hi Keith,
> Steve
> Sent from my iPhone
>> Steve
> be
> at
> battery
>> further back
>> Keith
> with
>> Sent from my iPhone
FORUMS -
WIKI -
b Site -
pastormac62
Posted: Wed Jan 11, 2017 6:08 am Post subject: Lens for landing light? |
Thanks Galin. What landing light did you use and wig wag??
On Jan 11, 2017, at 8:55 AM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
| Quote: | My airplane was already built so the shape was already there.
Hi Guys,
Thanks!
Steve
> Steve
> Keith
> Hi Keith,
> Steve
> Sent from my iPhone
>> Steve
> be
> at
> battery
>> further back
>> Keith
> with
>> Sent from my iPhone
FORUMS -
WIKI -
b Site -
wschertz343(at)gmail.com Guest
Posted: Wed Jan 11, 2017 8:03 am Post subject: Lens for landing light? |
Another technique that keeps the heat away from the leading edge of the week during formation is:
1. Cover the leading edge with packing tape or saran wrap
2. Build a box around the leading edge with cardboard to retain the next step
3. Fill the box with pour-foam, or use Great Stuff from the hardware store
4. Let it cure, then remove from the leading edge. This makes a female mold
5. Make sure you use tape or mold release on the inside of the mold, and fill it with plaster of paris, let cure
6. Heat the acrylic in an oven, and drape it over the mold.
Bob Reed’s web site has a short piece I wrote on installing the lenses after they are formed.
Bill Schertz
Sent: Wednesday, January 11, 2017 7:08 AM
Subject: Re: Lens for landing light?
Hi Guys,
Thanks!
Steve
| Quote: | On Jan 3, 2017, at 4:09 AM, Keith.Miller(at)esa.int (Keith.Miller(at)esa.int) wrote:
Steve
Keith
Subject: Re: KIS-List: Gross Weight of TR-1?
Hi Keith,
Steve
> Steve
be
at
battery
> further back
> Keith
with
> Sent from my iPhone
FORUMS -
WIKI -
b Site -
Posted: Wed Jan 11, 2017 11:11 am Post subject: Lens for landing light? |
I went with the AeroLED AeroSun 800, which are no longer sold. They replaced them with the AeroSun 1600 which is a little longer. They are AWESOME!
http://aeroleds.com/shop/aerosun/?val=aeroleds
You can also find great LED lights at Baja Designs:
https://www.bajadesigns.com/products/S2-Pro-LED-Light-Black-Flush-Mount.asp
On Wed, Jan 11, 2017 at 9:08 AM, <pastormac(at)comcast.net (pastormac(at)comcast.net)> wrote:
| Quote: | Thanks Galin. What landing light did you use and wig wag??
Â
Hi Guys,
Thanks!
Steve
> Steve
> Keith
> Hi Keith,
> Steve
> Sent from my iPhone
>> Steve
> be
> at
> battery
>> further back
>> Keith
> with
>> Sent from my iPhone
FORUMS -
WIKI -
b Site -
Posted: Wed Jan 11, 2017 12:05 pm Post subject: Lens for landing light? |
Just out of curiosity, has anybody installed a landing light in the cowl of a TR-1 or TR-4?
On Wed, Jan 11, 2017 at 2:10 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
| Quote: | I went with the AeroLED AeroSun 800, which are no longer sold. They replaced them with the AeroSun 1600 which is a little longer. They are AWESOME!
Â
Hi Guys,
Thanks!
Steve
> Steve
> Keith
> Hi Keith,
> Steve
> Sent from my iPhone
>> Steve
> be
> at
> battery
>> further back
>> Keith
> with
>> Sent from my iPhone
FORUMS -
WIKI -
b Site -
fredorosa(at)gmail.com Guest
Posted: Wed Jan 11, 2017 2:29 pm Post subject: Lens for landing light? |
I would have a taxi light on each wing and put the landing light in the cowl.
That was my plan.
Al Rosa
On Jan 11, 2017, at 3:04 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
| Quote: | Just out of curiosity, has anybody installed a landing light in the cowl of a TR-1 or TR-4?
Hi Guys,
Thanks!
Steve
> Steve
> Keith
> Hi Keith,
> Steve
> Sent from my iPhone
>> Steve
> be
> at
> battery
>> further back
>> Keith
> with
>> Sent from my iPhone
FORUMS -
WIKI -
b Site -
hansoncp(at)netnitco.net Guest
Posted: Wed Jan 18, 2017 12:31 pm Post subject: Lens for landing light? |
Hi Steve, I have attached (I hope) a picture of a lens former I made for my
TR4 wing. I cut the wing leading edge out to the length I needed for a
landing and taxi light, then used that cutout as a mold to pour plaster of
paris into to make a form for shaping the lens in the oven. When that didn't
work as well as I wanted, I made a better wood shape and covered it with
metal for a great former that worked fine. A finished lens is shown next to
it. I don't know if the four place leading edge is the same as the two place
but you are welcome to use my former if you want. I may be in INDY next
Tuesday if you would like me to bring it and we could meet up.
| Description: |
| Filesize: |
135.45 KB |
| Viewed: |
14448 Time(s) |
pastormac62
Posted: Sun Jan 22, 2017 12:57 pm Post subject: Lens for landing light? |
Hi Ed!!
Yes, bring it!!! Would so enjoy meeting you!!
Steve
[quote] On Jan 18, 2017, at 3:30 PM, Ed Hanson <hansoncp(at)netnitco.net> wrote:
Hi Steve, I have attached (I hope) a picture of a lens former I made for my TR4 wing. I cut the wing leading edge out to the length I needed for a landing and taxi light, then used that cutout as a mold to pour plaster of paris into to make a form for shaping the lens in the oven. When that didn't work as well as I wanted, I made a better wood shape and covered it with metal for a great former that worked fine. A finished lens is shown next to it. I don't know if the four place leading edge is the same as the two place but you are welcome to use my former if you want. I may be in INDY next Tuesday if you would like me to bring it and we could meet up.
