jpoint(at)wi.rr.com Guest
Posted: Sat Feb 11, 2017 6:03 am Post subject: Z-17/ alternator wire protection |
Hello,
I am confused about the requirements for protection of the A/C wires
from the alternator. I'm planning to use Z-17 as the basis for my
electrical design for my simple, day-VFR aircraft. Battery will be a
Earth-X 680, alternator is a B&C 200G, along with a B&C starter on an O-200.
The drawing that came with the alternator shows a 15A fuse in one of the
A/C lines from the alternator to the regulator, as well as a 15A breaker
between the crowbar relay and the power bus. However, Z-17 omits the
fuse in the A/C wires but does put a fusible link between the crowbar
relay and the battery (via the hot post of the starter contactor.)
Other Z- drawings using the SD-8/ 200G also omit the fuse in the A/C
wiring. The only drawing I've found which includes it is the one from B&C.
Is the fuse in the A/C wires required?
Thanks.
Jeff Point
Milwaukee WI
Posted: Sat Feb 11, 2017 7:18 am Post subject: Z-17/ alternator wire protection |
At 07:54 AM 2/11/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com>
Hello,
I am confused about the requirements for protection of the A/C wires from the alternator. I'm planning to use Z-17 as the basis for my electrical design for my simple, day-VFR aircraft. Battery will be a Earth-X 680, alternator is a B&C 200G, along with a B&C starter on an O-200.
The drawing that came with the alternator shows a 15A fuse in one of the A/C lines from the alternator to the regulator, as well as a 15A breaker between the crowbar relay and the power bus. However, Z-17 omits the fuse in the A/C wires but does put a fusible link between the crowbar relay and the battery (via the hot post of the starter contactor.)
Other Z- drawings using the SD-8/ 200G also omit the fuse in the A/C wiring. The only drawing I've found which includes it is the one from B&C.
Is the fuse in the A/C wires required? |
The two-fuse combination of protection considers the fact
that energy capable of burning wires in the
PM alternator system comes from TWO directions.
(1) fault in the R/R that places high load on
alternator and (2) fault - perhaps the same one -
that loads the battery.
I recommend 15A inline fuses at both locations.
This fuseholder is one of several options suited
to the task.
http://tinyurl.com/gmpr8j2
Joined: 28 Mar 2008 Posts: 1969 Location: Riley TWP Michigan
Posted: Sat Feb 11, 2017 7:42 am Post subject: Re: Z-17/ alternator wire protection |
No, the AC fuse is not required because the generator is self current limiting. The alternator could overheat if the output is shorted or very heavily loaded. A fuse might protect against that. On the other hand, a fuse in the AC output is one more thing that could fail and cause the aircraft to lose electrical power.
The output of an alternator does not normally have over-current protection. However the "B" lead is protected by a fuse at the battery end. That fuse protects the battery and the "B" lead from battery current, not from alternator output current.
_________________ Joe Gores |
Posted: Sat Feb 11, 2017 8:54 am Post subject: Z-17/ alternator wire protection |
At 09:42 AM 2/11/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com>
No, the AC fuse is not required because the generator is self current limiting. |
Yeah . . . mostly . . . indeed, an SD-8 turning
4K RPM max is at little risk for smoke due to
hard fault. But that's a condition I'll check
next time I get on the test bench.
The 200G on a Continental is belt driven with
a pretty high ratio. This is why, with the SAME
magnetics, it is rated at 12A output. It's almost
a certainty that this machine would smoke seriously
if the R/R presents a hard fault.
Posted: Sat Feb 11, 2017 9:02 am Post subject: Re: Z-17/ alternator wire protection |
Oops. Bob posted his reply while I was still composing mine. And my reply contradicts his. So now I am confused. Why doesn't Z-13/8 or Z-17 have a fuse protecting the dynamo AC output?
ceengland7(at)gmail.com Guest
Posted: Sat Feb 11, 2017 11:49 am Post subject: Z-17/ alternator wire protection |
On 2/11/2017 11:02 AM, user9253 wrote:
Joe Gores
Hi Joe,
Any chance you're thinking about a regular field type alternator, and
the one being discussed is a dynamo?
Posted: Sun Feb 12, 2017 6:23 am Post subject: Z-17/ alternator wire protection |
On 2/11/17 10:51 AM, Robert L. Nuckolls, III wrote:
On my O-200 it is mounted on the vacuum pad and is gear driven from the
cam gear. Nevertheless I will take your advice and put a 15A fuse in
both locations. Final question- the drawing from B&C only shows the
fuse on one of the two A/C wires from the dynamo to the regulator.
Since there is no polarity to these wires, I assume this is because it
is AC voltage?
Jeff
Posted: Sun Feb 12, 2017 11:03 am Post subject: Z-17/ alternator wire protection |
if the R/R presents a hard fault. | On my O-200 it is mounted on the vacuum pad and is gear driven from the cam gear. Nevertheless I will take your advice and put a 15A fuse in both locations. Final question- the drawing from B&C only shows the fuse on one of the two A/C wires from the dynamo to the regulator.
Since there is no polarity to these wires, I assume this is because it is AC voltage? |
No, it's because the alternator output is
a loop that goes to zero current when
opened anywhere in that loop . . . one
fuse suffices for both leads.
blues750
Posted: Mon Feb 13, 2017 8:47 am Post subject: Re: Z-17/ alternator wire protection |
"No, it's because the alternator output is
fuse suffices for both leads."
Would I be assuming correctly this is also true for a three phase PMA?
Posted: Mon Feb 13, 2017 9:00 am Post subject: Re: Z-17/ alternator wire protection |
No, to stop three phase current, at least two of the three phases must be opened.
blues750
