W1002 Weldment Query
kearney
PostPosted: Sat Feb 11, 2017 12:37 pm    Post subject: W1002 Weldment Query Reply with quote
When I built my -10, I had a very difficult time getting reasonable edge distances on the W1002 weldment when match drilled to the F1001B & F1004. For those haven't memorized the VANS plans & part numbers, these are the weldments that tie the engine mount to to the firewall / fuse.
Has anyone else had a problem with these?
Inquiring minds need to know...
Cheers
Les
Bob Turner
PostPosted: Sat Feb 11, 2017 2:52 pm    Post subject: Re: W1002 Weldment Query Reply with quote
If it's the engine mount you're talking about, yes, mine were way off. After consulting with Vans I pushed and pulled on the mount, by hand, as hard as I could, and then tied it with rope to hold that configuration. That allowed the very undersized pilot holes to be within, but no where near centered, when viewed thru the mount holes. I used the mount as a guide for the drill bit, and got clean, round holes when done. But not centered on the original pilot holes.
Bob Turner
RV-10 QB
bill.peyton
PostPosted: Sun Feb 12, 2017 5:29 am    Post subject: Re: W1002 Weldment Query Reply with quote
I too had issues with alignment. I used a rope and Polly to stretch the mount. I was able to get all holes lined up. I started with the top, which lined up without much effort for me, then the bottom two outside holes which required a lot of stretching. The hard part was inserting the bolts after having to remove the mount again.
Bill
WA0SYV
Aviation Partners, LLC
kearney
PostPosted: Sun Feb 12, 2017 7:17 am    Post subject: Re: W1002 Weldment Query Reply with quote
Hmmm
This sounds like the problem I had. Unfortunately, when I used clamps and ropes etc there was a significant flex in the firewall due to the weldments. To me it seems like there is a design issue here.
Cheers
Les
philperry9
PostPosted: Sun Feb 12, 2017 8:05 am    Post subject: W1002 Weldment Query Reply with quote
All these problems makes me want to go back and re-check mine. I didn't have any issues.
On Feb 12, 2017, at 9:17 AM, kearney <kearney(at)shaw.ca> wrote:
Hmmm
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=466046#466046
jesse(at)saintaviation.co
PostPosted: Sun Feb 12, 2017 10:06 am    Post subject: W1002 Weldment Query Reply with quote
The W1002 is not the engine mount. He's talking about the part that it bolts to aft of the firewall.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
> Hmmm
> Cheers
> Les
Kelly McMullen
PostPosted: Sun Feb 12, 2017 12:16 pm    Post subject: W1002 Weldment Query Reply with quote
The area being discussed was built for you in your quick build.
-sent from the I-droid implanted in my forearm
On Sun, Feb 12, 2017 at 8:56 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
--> RV10-List message posted by: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
> On Feb 12, 2017, at 9:17 AM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
> --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
> Hmmm
> Cheers
> Les
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
