				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| ploucandco
				|  Posted: Sat Feb 11, 2017 1:59 pm    Post subject: ROTAX914 pressure sensor 4mm PVC tube |   |
				| Hello, I need to replace/reroute some hoses in my 914 firewall. And looking where I can find a 4mm PVC tube for the 914 pressure sensor that is supporting high temperature found in the firewall. This one needs to end up near the air filter of the turbo.
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| h&jeuropa
				|  Posted: Sun Feb 12, 2017 5:12 am    Post subject: Re: ROTAX914 pressure sensor 4mm PVC tube |   |
				| Rotax sells this as a replacement part (P/N 860 660), but it is very expensive and in the US few of the distributors have it in stock.  There are suitable automotive hoses available.
 Jim
		| Back to top |  |
		| rlborger(at)mac.com Guest
				|  Posted: Sun Feb 12, 2017 8:40 am    Post subject: ROTAX914 pressure sensor 4mm PVC tube |   |
				| I’ll bet you can find a suitable hose/tubing here:
https://www.mcmaster.com/#standard-plastic-and-rubber-tubing/=16bnwhx
 if not at a good auto supply store.
 Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX  76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
 On Feb 11, 2017, at 3:59 PM, ploucandco <jacques(at)platisource.com (jacques(at)platisource.com)> wrote:
 --> Europa-List message posted by: "ploucandco" <jacques(at)platisource.com (jacques(at)platisource.com)>Hello, I need to replace/reroute some hoses in my 914 firewall. And looking where I can find a 4mm PVC tube for the 914 pressure sensor that is supporting high temperature found in the firewall. This one needs to end up near the air filter of the turbo.Read this topic online here:http://forums.matronics.com/viewtopic.php?p=466025#466025
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
