philipgeorge347(at)hotmai Guest
Posted: Thu Feb 09, 2017 1:44 pm Post subject: Airmaster prop problems. |
I hope someone can help . We are at present test flying G-JAGY a Europa mono imported from the US and converted to a Tri-gear by Nev Eyre. It’s a 914 with Airmaster prop with Warp drive blades and the original AC100 controller.
whilst test flying the prop works ok in manual mode. Switching to Auto it runs to full fine . How does it detect RPM is it the sensor on the back of the spinner flange? If so is it a light sensing counter using a light source ? If this all sounds a bit vague I am a third party relaying this request and my Europa does not have a VP prop. Some advice on the operation would be of great help. As Airmaster do not support the old AC100 controller any longer.
Any help would be much appreciated .
Philip George.
Sent from Mail for Windows 10
JonathanMilbank
Joined: 14 Apr 2012 Posts: 395 Location: Aberdeen area
Posted: Thu Feb 09, 2017 3:29 pm Post subject: Re: Airmaster prop problems. |
A couple of years ago I converted my Airmaster from AC100 to AC200 controller. The AC100 was working fine and I still have most of the components.
There are three concentric rings of black "squares" at the rear of the spinner and the detector attached to the side of the gearbox has three photocells aligned with the rings to "count" the number of squares going by in each propeller revolution. The rings correspond to Take-Off, Climb and Cruise rpm.
I did experience on at least one occasion at low light levels that the photocells weren't detecting the squares, but I can't remember what the response was i.e. did the propeller rpm go to fine pitch? That would make sense I guess.
Contact me if you want more help or info.
ken carp
Joined: 31 Oct 2008 Posts: 29 Location: Knoxville, TN
Posted: Thu Feb 09, 2017 3:46 pm Post subject: Airmaster prop problems. |
I think my controller may be like yours. Take off at full fine , then turn it back to climb and later to cruise if you like. I was thinking the fine setting was labeled take off. I had some problem with the controller ten years ago and had to sent it to Florida dealer to be re- booted. Has been no problem since and now at 650 hours. I think there must be a sensor on the spinner back plate.
Sent from my iPadKen Carpenter
On Feb 9, 2017, at 4:42 PM, philip george <philipgeorge347(at)hotmail.com (philipgeorge347(at)hotmail.com)> wrote:
Philip George.
_________________ ken carpenter |
Roland
Posted: Fri Feb 10, 2017 12:17 am Post subject: Re: Airmaster prop problems. |
I can strongly recommend to get in contact with Martin from Airmaster - he is VERY helpful.
My Europa is at the Belgian Airmaster dealer Oyen CTR just now. Dirk Oyen also knows the complete propeller system in depth.
Good luck with the troubleshooting.
Roland
PH-ZTI
XS TG 914
Posted: Tue Feb 14, 2017 2:26 am Post subject: Airmaster prop problems. |
I have limited experience of the Whirlwind blades but they do seem to be much nicer than the Warp Drive ones, which are much too stiff and cause a lot of vibration as a result.
The aerodynamics also are more optimized for the performance the Europa is capable of. Warp Drive seem to have changed little from the original target market of weight shift microlights.
All my opinion of course so don't forget the salt!
Graham
On Friday, 10 February 2017, 8:58, Roland <schmidtroland(at)web.de> wrote:
--> Europa-List message posted by: "Roland" <schmidtroland(at)web.de (schmidtroland(at)web.de)>I can strongly recommend to get in contact with Martin from Airmaster - he is VERY helpful.My Europa is at the Belgian Airmaster dealer Oyen CTR just now to get its new Whirlwind blades installed Dirk Oyen also knows the complete propeller system in depth. Good luck with the troubleshooting.RolandPH-ZTIXS TG 914Read this topic online here:http://forums.matronics.com/viewtopic.php?p=465957#465957http://forums.matronics.c="nofollow" shape="rect" target="_blank" href="http://wiki.matronicnbsp; rel="nofollow" shape="rect" target="_blank" href="http://www.matronics.com/contribution">http://www.matronics.com/contribution[/url]
