Z-17/ alternator wire protection
jpoint(at)wi.rr.com
PostPosted: Sat Feb 11, 2017 6:03 am    Post subject: Z-17/ alternator wire protection Reply with quote
Hello,
I am confused about the requirements for protection of the A/C wires
from the alternator. I'm planning to use Z-17 as the basis for my
electrical design for my simple, day-VFR aircraft. Battery will be a
Earth-X 680, alternator is a B&C 200G, along with a B&C starter on an O-200.
The drawing that came with the alternator shows a 15A fuse in one of the
A/C lines from the alternator to the regulator, as well as a 15A breaker
between the crowbar relay and the power bus. However, Z-17 omits the
fuse in the A/C wires but does put a fusible link between the crowbar
relay and the battery (via the hot post of the starter contactor.)
Other Z- drawings using the SD-8/ 200G also omit the fuse in the A/C
wiring. The only drawing I've found which includes it is the one from B&C.
Is the fuse in the A/C wires required?
Thanks.
Jeff Point
Milwaukee WI
PostPosted: Sat Feb 11, 2017 7:18 am    Post subject: Z-17/ alternator wire protection Reply with quote
At 07:54 AM 2/11/2017, you wrote:
--> AeroElectric-List message posted by: Jeff Point <jpoint(at)wi.rr.com>
Hello,
I am confused about the requirements for protection of the A/C wires from the alternator. I'm planning to use Z-17 as the basis for my electrical design for my simple, day-VFR aircraft. Battery will be a Earth-X 680, alternator is a B&C 200G, along with a B&C starter on an O-200.
The drawing that came with the alternator shows a 15A fuse in one of the A/C lines from the alternator to the regulator, as well as a 15A breaker between the crowbar relay and the power bus. However, Z-17 omits the fuse in the A/C wires but does put a fusible link between the crowbar relay and the battery (via the hot post of the starter contactor.)
Other Z- drawings using the SD-8/ 200G also omit the fuse in the A/C wiring. The only drawing I've found which includes it is the one from B&C.
The two-fuse combination of protection considers the fact
that energy capable of burning wires in the
PM alternator system comes from TWO directions.
(1) fault in the R/R that places high load on
alternator and (2) fault - perhaps the same one -
that loads the battery.
I recommend 15A inline fuses at both locations.
This fuseholder is one of several options suited
to the task.
http://tinyurl.com/gmpr8j2
PostPosted: Sat Feb 11, 2017 7:42 am    Post subject: Re: Z-17/ alternator wire protection Reply with quote
No, the AC fuse is not required because the generator is self current limiting. The alternator could overheat if the output is shorted or very heavily loaded. A fuse might protect against that. On the other hand, a fuse in the AC output is one more thing that could fail and cause the aircraft to lose electrical power.
The output of an alternator does not normally have over-current protection. However the "B" lead is protected by a fuse at the battery end. That fuse protects the battery and the "B" lead from battery current, not from alternator output current.
Joe Gores
PostPosted: Sat Feb 11, 2017 8:54 am    Post subject: Z-17/ alternator wire protection Reply with quote
Yeah . . . mostly . . . indeed, an SD-8 turning
4K RPM max is at little risk for smoke due to
hard fault. But that's a condition I'll check
next time I get on the test bench.
The 200G on a Continental is belt driven with
a pretty high ratio. This is why, with the SAME
magnetics, it is rated at 12A output. It's almost
a certainty that this machine would smoke seriously
if the R/R presents a hard fault.
PostPosted: Sat Feb 11, 2017 9:02 am    Post subject: Re: Z-17/ alternator wire protection Reply with quote
Oops. Bob posted his reply while I was still composing mine. And my reply contradicts his. So now I am confused. Why doesn't Z-13/8 or Z-17 have a fuse protecting the dynamo AC output?
Joe Gores
ceengland7(at)gmail.com
PostPosted: Sat Feb 11, 2017 11:49 am    Post subject: Z-17/ alternator wire protection Reply with quote
Joe Gores
Hi Joe,
Any chance you're thinking about a regular field type alternator, and
the one being discussed is a dynamo?
jpoint(at)wi.rr.com
PostPosted: Sun Feb 12, 2017 6:23 am    Post subject: Z-17/ alternator wire protection Reply with quote
On my O-200 it is mounted on the vacuum pad and is gear driven from the
cam gear. Nevertheless I will take your advice and put a 15A fuse in
both locations. Final question- the drawing from B&C only shows the
fuse on one of the two A/C wires from the dynamo to the regulator.
Since there is no polarity to these wires, I assume this is because it
is AC voltage?
Jeff
PostPosted: Sun Feb 12, 2017 11:03 am    Post subject: Z-17/ alternator wire protection Reply with quote
On my O-200 it is mounted on the vacuum pad and is gear driven from the cam gear. Nevertheless I will take your advice and put a 15A fuse in both locations. Final question- the drawing from B&C only shows the fuse on one of the two A/C wires from the dynamo to the regulator.
Since there is no polarity to these wires, I assume this is because it is AC voltage?
No, it's because the alternator output is
a loop that goes to zero current when
opened anywhere in that loop . . . one
fuse suffices for both leads.
blues750
PostPosted: Mon Feb 13, 2017 8:47 am    Post subject: Re: Z-17/ alternator wire protection Reply with quote
"No, it's because the alternator output is
fuse suffices for both leads."
Would I be assuming correctly this is also true for a three phase PMA?
PostPosted: Mon Feb 13, 2017 9:00 am    Post subject: Re: Z-17/ alternator wire protection Reply with quote
No, to stop three phase current, at least two of the three phases must be opened.
Joe Gores
blues750
PostPosted: Mon Feb 13, 2017 9:03 am    Post subject: Re: Z-17/ alternator wire protection Reply with quote
Agree...found my notes on this topic along with a drawing by Bob on how to disconnect 3 phase PMA. Rolling Eyes
