		william(at)wbliss.co.uk Guest
				 Posted: Thu Feb 16, 2017 1:38 pm    Post subject: Tapered tailwheel spring twist |
				Hello all
 The new tapered tailwheel spring I received has a twist along its
 length. When I inserted the mounting bolt in its hole and looked along
 to see how well the spring shaft aligned with the bolt it seemed to be
 out of line. Difficult to measure accurately but about 2 degrees.
 Is it reasonable to expect perfect alignment?
 William Bliss G-WUFF
		budyerly(at)msn.com Guest
				 Posted: Sat Feb 18, 2017 1:12 pm    Post subject: Tapered tailwheel spring twist |
				William,
 It should be straight.  I.e.  The spindle and hole for the bolt should be aligned very close.  Check that the flat spot and hole bore are 90 degrees to each other.  Get a new spring or put the spring hold down bolt off a couple of degrees and adjust the metal support plate and buildup of ply to match the slight misalignment.  Not hard, just one must be aware.
 Bud Yerly
