Ragwing Ultra-Piet
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
taildrags
PostPosted: Thu Mar 01, 2018 8:38 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
wingnut: not trying to dampen your enthusiasm one bit! Right now everything is safe and sound in your shop and you have all the time in the world to look at things from all angles. Carry on, but verify everything while it can still be adjusted. If Grant McLaren's Ultra Piet build pix are available anywhere out there, you should study those. His was an award-winner and a good flyer.
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
cdlwingnut
PostPosted: Sun Mar 11, 2018 5:21 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I managed to spend a couple of hours in the shop today. The door is hung back on. Then started on the landing gear. The left leg is cut and glued in the jig.
 Filesize:  201.04 KB
 Viewed:  4099 Time(s)
 Filesize:  211.47 KB
Catdesigns
PostPosted: Sun Mar 11, 2018 6:55 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Is it supposed to have a door?
Chris
Try the top-rated email app
On Sun, Mar 11, 2018 at 6:22 PM, cdlwingnut
<lee_chad(at)hotmail.com> wrote:
--> Pietenpol-List message posted by: "cdlwingnut" <lee_chad(at)hotmail.com (lee_chad(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=478594#478594
http://forums.matronics.com//files/20180311_155004_resized_207.jpg
http://forums.matronics.com//files/20180311_155013_resized_558.jpg
http://www.matronics.com= - MATRONICS WEB FORUMS= --> /wiki.matronics.com" target="_blank">http://wiki.matronics.com
http://www.mat====
Chris
Sacramento, CA
WestCoastPiet.com
taildrags
PostPosted: Sun Mar 11, 2018 7:12 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Chris; go back up this thread to Dan Oliver's post on Thursday March 1 where there is a sketch of the UltraPiet shown. It indicates a hinged door on the starboard side. By the way, unless I'm mistaken, Dan Oliver built and flew an award-winning JN-4 scale replica powered by an inline 4-cylinder like the Geo engine or something. Maybe I've got my names and planes mixed up though.
He took some pictures of his airplane for me many years ago, since I wanted to get some ideas on how he rigged his heel brakes.
Oscar Zuniga
Medford, OR
cdlwingnut
PostPosted: Mon Mar 12, 2018 4:58 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Yes there is a door. It can be a fold down type or like mine
http://rogermann.org/ragwing/files/2012/06/ultrapiet.jpg
cdlwingnut
PostPosted: Tue Mar 13, 2018 9:24 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
So pulled the gear leg out of the jig and put it against the fuselage to test the fit. Wasnt even close. Did some trimming and ended up with a leg way out of spec. Scrapped it and did take two with a template of the bottom of the fuselage to go by. Hopefully this one will fit better.
 Filesize:  178.16 KB
 Viewed:  4051 Time(s)
 Filesize:  147.78 KB
glen
PostPosted: Tue Mar 13, 2018 12:51 pm    Post subject: Ragwing Ultra-Piet Reply with quote
I built an ultrapiet years ago. Always check dimensions using actual parts you’ve built. Seems like a lot of the drawing dimensions don’t match previously built parts. Have you done cabanas or center section yet? LOOK OUT? Weight and balance was way off too. Be really careful. Flying it was fun but for the money, you might be further ahead and build a scout
http://forums.matronics.com/viewtopic.php?p=478644#478644
http://forums.matronics.com//files/20180313_105112_resized_263.jpg
http://forums.matronics.com//files/20180313_105117_resized_626.jpg
View user's profile Send private message Send e-mail Yahoo Messenger
danoliver
PostPosted: Tue Mar 13, 2018 1:07 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Must be a different Dan Oliver. I only have a set of Ultrapiet plans because that's what I was going to build originally. After looking into it more, I figured it wouldn't be much harder to just go ahead and build a regular Piet.
Dan O
cdlwingnut
PostPosted: Wed Mar 14, 2018 5:22 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
The second attempt at the gear leg came out much better
cdlwingnut
PostPosted: Mon Mar 19, 2018 4:20 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Did a little more work on the landing gear. I cut two plywood sides out for the right leg and glued one side on.
 Filesize:  219.59 KB
 Viewed:  3954 Time(s)
Ray Krause
PostPosted: Mon Mar 19, 2018 7:06 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Those bricks might be a tad bit heavy?
Ray Krause
http://forums.matronics.com/viewtopic.php?p=478744#478744
http://forums.matronics.com//files/20180319_164013_resized_103.jpg
cdlwingnut
PostPosted: Wed Mar 21, 2018 2:52 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Just want it nice and strong ray built like a brick.
The left leg is ready for the router and varnishing. Cutting out the plywood sides for the right leg.
 Filesize:  198.74 KB
 Viewed:  3921 Time(s)
cdlwingnut
PostPosted: Fri Mar 23, 2018 3:43 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Spent a good part of the day working on my landing gear. The left one is tempararly on the fuselage to test the fit. Still have some work to do like more varnish and rounding off the edges. The right on has the plywood glued to the sides and is waiting for the t-88 to cure.
 Filesize:  208.98 KB
 Viewed:  3897 Time(s)
cdlwingnut
PostPosted: Mon Mar 26, 2018 3:57 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
A little more progress on the gear leg. Now to start on the right side. Then take them back off to varnish, use a router to round off and varnish the bolt holes. Oh i know i will need shorter bolt and maybe some washers. I couldnt help taking a picture of the wheel sitting next to it
 Filesize:  268.61 KB
 Viewed:  3848 Time(s)
 Filesize:  192.38 KB
 Filesize:  174.27 KB
cdlwingnut
PostPosted: Tue Mar 27, 2018 3:03 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Did some work on the right gear leg. I got it far enough along to place the axle in position and slide the wheels on for a sneak preview.
 Filesize:  262.34 KB
 Viewed:  3813 Time(s)
kipgohio1957(at)gmail.com
PostPosted: Tue Mar 27, 2018 3:43 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Looks nice!
http://forums.matronics.com/viewtopic.php?p=478898#478898
http://forums.matronics.com//files/20180327_161851_resized_192.jpg
cdlwingnut
PostPosted: Tue Apr 03, 2018 2:22 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Progress update. Metal fasteners are fabricated and did the seat belt attachments. Then the gear was removed so i can use a router on it to round off the edges. I also need to varnish it and the holes i drilled in the wood. I did some varnishing and made rudder peddles. The posts for the center section are cut out of fir.
 Filesize:  209.79 KB
 Viewed:  3682 Time(s)
 Filesize:  193.14 KB
 Filesize:  224.26 KB
 Filesize:  215.53 KB
 Filesize:  203.79 KB
Brian.Jardine(at)Plexus.c
PostPosted: Tue Apr 03, 2018 2:37 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Nice progress. What glue are you using on your wood structure, hopefully its T-88 epoxy.
Brian
Meridian, ID
cdlwingnut
PostPosted: Tue Apr 03, 2018 4:18 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Yes im using T88
cessna7226g(at)aol.com
PostPosted: Tue Apr 03, 2018 5:01 pm    Post subject: Ragwing Ultra-Piet Reply with quote
The bottom of your gear isn't at the right angle.
Making the gear leg is the hardest part of the project
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 3 of 6
