Ragwing Ultra-Piet
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
cdlwingnut
PostPosted: Tue Apr 03, 2018 5:19 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
What do you mean Cessna. The gear leg has no right angles and it goes out from the fuselage at a 37 deg angle
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
bickers.ken(at)gmail.com
PostPosted: Tue Apr 03, 2018 6:28 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Chad, I suspect that what Cessna is referring to is the orientation of the short block that will be parallel to the ground during landings.  The angle at which it is currently set is not flat relative to the axle.  Take a look at that piece from the Jenny-style gear that I originally had on my Piet. Ken
On Tue, Apr 3, 2018 at 7:19 PM, cdlwingnut <lee_chad(at)hotmail.com (lee_chad(at)hotmail.com)> wrote:
--> Pietenpol-List message posted by: "cdlwingnut" <lee_chad(at)hotmail.com (lee_chad(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=479026#479026
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
WIKI -
 Filesize:  1.62 MB
 Viewed:  4747 Time(s)
cdlwingnut
PostPosted: Tue Apr 03, 2018 6:39 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I see what you mean now
cdlwingnut
PostPosted: Wed Apr 11, 2018 5:26 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
After rechecking my plans and looking at pictures of other ultra piets the bottom block is not angled down to be perbendicular to the ground. I may still consider making mine so anyway though.
I have been working on my center supports some more though
 Filesize:  290.71 KB
 Viewed:  4673 Time(s)
 Filesize:  215.34 KB
cdlwingnut
PostPosted: Fri Apr 13, 2018 4:57 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Put in a little more work on the center section. The posts are test fitted. Keeping it all square when glueing will be a challenge. How did you all do it.
 Filesize:  277.6 KB
 Viewed:  4652 Time(s)
cdlwingnut
PostPosted: Thu Apr 19, 2018 5:32 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
More work on the center section
 Filesize:  302.84 KB
 Viewed:  4609 Time(s)
 Filesize:  298.67 KB
cdlwingnut
PostPosted: Fri Apr 27, 2018 4:25 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I have been working on my center section as well. My uprights are glued in and stained. I also stained the gear legs as well. I pit brake drums on my wheels and picked up the engine. Dont worry the engine will get some TLC before i fly with it.
 Filesize:  266.9 KB
 Viewed:  4549 Time(s)
 Filesize:  252 KB
 Filesize:  288.07 KB
 Filesize:  289.43 KB
 Filesize:  266.76 KB
cdlwingnut
PostPosted: Fri May 18, 2018 6:41 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Work has slowed down on the little piet project with the better weather I have been flying more than building. I have done a lot of varnishing I measured and cut the plywood for the top of the front. The brace wires are now in place for the center section. I have also tinkered with the engine a little.
 Filesize:  291.97 KB
 Viewed:  4457 Time(s)
 Filesize:  292.39 KB
 Filesize:  214.1 KB
 Filesize:  258.3 KB
cdlwingnut
PostPosted: Thu Jun 14, 2018 6:05 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I haven't given up on the little piet. Summer has been busy so far all the new progress i have made is cutting aluminum for the control stick and torque tube.
 Filesize:  266.11 KB
 Viewed:  4259 Time(s)
cdlwingnut
PostPosted: Wed Jun 27, 2018 1:19 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Working on my control tube and stick some more.
And stained what will be the instument pannel. I havent had a lot of time for the project as kts been a buisy summer. Getting in a few mins here and there
 Filesize:  298.35 KB
 Viewed:  4177 Time(s)
 Filesize:  322.4 KB
cdlwingnut
PostPosted: Fri Jul 13, 2018 2:05 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Been working on the little piet here and there. The landing gear is coming along. The torque tube and controll stick is completed and installed. Lots of varnishing.
 Filesize:  195.78 KB
 Viewed:  4073 Time(s)
 Filesize:  296 KB
 Filesize:  314.05 KB
 Filesize:  221.82 KB
 Filesize:  298.35 KB
 Filesize:  322.4 KB
cdlwingnut
PostPosted: Wed Jul 25, 2018 6:26 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I got the wheels back on and the instruments in the panel. Doing lots of sanding and varnishing. Wont be too much longer to set the fuselage aside and start building wing spars.
 Filesize:  272.1 KB
 Viewed:  3994 Time(s)
 Filesize:  296 KB
cdlwingnut
PostPosted: Thu Sep 20, 2018 5:53 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I have been slowly plugging away. The back turtle deck is done. And have started a wing spar.
 Filesize:  201.24 KB
 Viewed:  3641 Time(s)
 Filesize:  277.67 KB
Ray Krause
PostPosted: Thu Sep 20, 2018 6:16 pm    Post subject: Ragwing Ultra-Piet Reply with quote
That looks really nice, wish I were building it. You lucky bum.
Ray Krause
Skyscout
N667RK
http://forums.matronics.com/viewtopic.php?p=483291#483291
http://forums.matronics.com//files/20180917_140746_resized_208.jpg
http://forums.matronics.com//files/20180803_131810_resized_191.jpg
glen
PostPosted: Thu Sep 20, 2018 7:52 pm    Post subject: Ragwing Ultra-Piet Reply with quote
That is the ultra Piet, yes?
On Sep 20, 2018, at 7:16 PM, (null) raykrause <raykrause(at)frontiernet.net> wrote:
Ray Krause
Skyscout
N667RK
View user's profile Send private message Send e-mail Yahoo Messenger
danoliver
PostPosted: Fri Sep 21, 2018 2:34 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I have said it before and I will say it again, your pace is inspirational!
Dan O
cdlwingnut
PostPosted: Fri Sep 21, 2018 6:39 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Thanks guys. Yes this is an ultra piet.
I got the front left spar glued and curing in the jig.
 Filesize:  213.28 KB
 Viewed:  3586 Time(s)
taildrags
PostPosted: Sat Sep 22, 2018 8:01 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
cdlwingnut- thanks for continuing to post progress photos. It's great fun to watch another airplane come together! Just be aware that we're all sitting here in our chairs watching what you're doing and it's a natural tendency to make comments from the peanut gallery. My comment just looking at the glue joints on your spar is that you shouldn't be too sparing with the epoxy. Use enough to completely fill the gap plus a little squeeze-out all around. You can always sand off or scrape off the squeeze-out if it's going to interfere with the next part of your assembly, but leaving part of the gap unfilled can create a stress riser at that location, and under stress the joint will want to separate at that point.
Anyway, you're proving the old adage that "those who say it can't be done should get out of the way of those who are doing it." Carry on ;o)
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
cdlwingnut
PostPosted: Sat Sep 22, 2018 11:16 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Thank you taildrag. One of the reasons for posting is so if someone sees somethkng they can say so. I did go back and fill those gaps and there will also be a sheet of plywood going over the whole spar so another chance to fill them too.
cdlwingnut
PostPosted: Mon Oct 01, 2018 2:29 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Second front spar is glued up in the jig.
 Filesize:  207.43 KB
 Viewed:  3420 Time(s)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 4 of 7
