RV10-List Digest: Fuel flow problem
deschamps(at)absamail.co.
PostPosted: Thu Feb 23, 2017 11:02 pm    Post subject: RV10-List Digest: Fuel flow problem Reply with quote
Hi Dan,
I had the same problem when flying above 9000 ft.
My fuel system had the Andair pump and filter in the tunnel with one
gascolator on the engine side of the firewall.
I removed the gascolator and this solved my problem.
There is too much resistance to the fuel flow with gascolator and fuel
filter installed.
Suggest that you remove the screen in one of the gascolators and with the
fuel selector on that side do a flight test to see if this will also solve
your problem.
Ed Deschamps
