fuel servo mounting
flying-nut(at)cfl.rr.com
PostPosted: Sat Feb 25, 2017 12:54 pm    Post subject: fuel servo mounting Reply with quote
I try and learn from 'oh crap' issues my friends have had. Today, my
RV-9 buddy had one. He probably has < 30 hours in phase 1 and went
flying this morning. About a 60 mile round trip and on the way home,
subtle engine surges followed by rough running and fuel smell. Dead
sticked into home base, and put the plane away. Cowl removed. Failure
easy to diagnose. Two nuts that should be holding the fuel servo
tightly to the engine were laying in the lower cowl, and the other two
were loose. Real loose. No torque seal in evidence, so the nuts may
not have been torqued down to start with.
So, I looked at my install (not flying yet and untorqued) and, like his,
I have nuts holding the servo on, but no locking nuts, lock washers or
safety wire. This begs the question ..... what have others done when
attaching the fuel servo??
I've already had my 3 'oh craps' and don't want to risk another!!!!
Linn
kdb.rv10(at)gmail.com
PostPosted: Sat Feb 25, 2017 1:03 pm    Post subject: fuel servo mounting Reply with quote
I use loctite and 2 nuts on each stud.
On Sat, Feb 25, 2017 at 2:52 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
I try and learn from 'oh crap' issues my friends have had.  Today, my RV-9 buddy had one.  He probably has < 30 hours in phase 1 and went flying this morning.  About a 60 mile round trip and on the way home, subtle engine surges followed by rough running and fuel smell.  Dead sticked into home base, and put the plane away.  Cowl removed.  Failure easy to diagnose.  Two nuts that should be holding the fuel servo tightly to the engine were laying in the lower cowl, and the other two were loose.  Real loose.  No torque seal in evidence, so the nuts may not have been torqued down to start with.
So, I looked at my install (not flying yet and untorqued) and, like his, I have nuts holding the servo on, but no locking nuts, lock washers or safety wire.  This begs the question ..... what have others done when attaching the fuel servo??
Linn
WIKI -
Lenny Iszak
PostPosted: Sat Feb 25, 2017 2:12 pm    Post subject: Re: fuel servo mounting Reply with quote
Hey Linn,
I used a flat washer and a star washer with blue Loctite. So far in 275 hours they haven't moved.
Nordlock washers might work great here. I first saw these on my Matco brakes, then someone posted this impressive video:
http://www.nord-lock.com/bolted/watch-the-new-junker-test-video-here/
Don't forget to safety wire the bolts holding the FAB mounting plate to the fuel servo.
Glad your buddy is ok.
Lenny
PostPosted: Sat Feb 25, 2017 2:43 pm    Post subject: fuel servo mounting Reply with quote
Thanks Lenny ..... I had forgotten about the Nordlock washers!!!
On 2/25/2017 5:12 PM, Lenny Iszak wrote:
Hey Linn,
Lenny
http://forums.matronics.com/viewtopic.php?p=466646#466646
Checked by AVG - www.avg.com
jrlark
PostPosted: Sat Feb 25, 2017 3:33 pm    Post subject: fuel servo mounting Reply with quote
Linn, my IO-540 has star washers underneath the 4 bolts heads. Haven't checked the torque but I will now.....Smile
Rick
