New Tailwheel
victorbravo(at)sbcglobal.
PostPosted: Wed Mar 22, 2017 10:06 pm    Post subject: New Tailwheel Reply with quote
Compression springs on the tail steering make it so there is no tension or force applied to the system whent he pilot is not steering. Which means there is no wear on the hinges, bolts, etc. ALL the time like there is on a tension spring system.
Compression springs are all-around much better for airplane use than tension springs.
Bill Berle
